Highway speed vibrations.
Car: 1983 Camaro Z/28
Engine: 305 HO
Transmission: 700r-4
Axle/Gears: stock
I have an 83 z28. I have the car lowered, with panhard bar with new shocks all the way around. New front and rear sway bar poly bushings and end links.
New 18 iroc rims on front and 20 on rear. Wheels and tires are freshly balanced. Around 60-75 the car is vibrating pretty bad. I would like to know if there is anything else I can change replace or adjust to correct my problem. I can’t tell if it’s from the front or rear. Randy
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Highway speed vibrations.
Wheels are probably not true. I had this problem with brand-new wheels from Circle Racing. I will NEVER do business with them again...
Engine: 305 HO
Axle/Gears: stock
I hear ya. These are American racing replicas from summit. The tires are an off brand lionhart. They balanced true.
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
What about drive shaft and u-joints?
Swapped my drive shaft and all my woes went away in the vibration department.
Engine: 305 HO
Axle/Gears: stock
I never really looked at the drive shaft. I’ll swap them out. And see. Thanks. Your driveshaft was out of balance?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You might check the trans mount, especially if you're running poly.
JamesC
JamesC
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
First have tires road forced and indexed to wheel properly. Most good tire stores or Dealers have the proper balancing machine to do this. A tire can be balanced put still vibrate from high road force readings. We do this daily with vibration problrms.
JOE
JOE
327_TPI_77_Maro
May 19, 2005 01:38 AM
Scott_92RS
Feb 19, 2002 06:21 PM
