Caster camber plate noise
Old Jan 21, 2019 | 01:10 PM
91vertZ28's Avatar
Car: 1991 Camaro Z28 Convertible
Wondering if caster camber plate noise is normal. Have had UMI caster camber plates on for almost a year and until recently have had issue with right side making noise. And unsure if also it is the cause of having a sort of tight spot on sterring when i turn wheel to the right. Local mechanic tightened up the strut part at top of plate and noise went away. But later returned after a couple weeks.
is this a common issue and any solutions recommended?
Old Jan 22, 2019 | 09:01 AM
UMI Sales's Avatar
Re: Caster camber plate noise
We have a few thousand sets out there and no particular noise complaints.
For tight spots in the steering, do you have coilovers and are they rubbing? That's the only real trouble (and it's unrelated to our product) as you're trying to fit a lot of stuff in a small space up there.
ramey
Old Jan 22, 2019 | 11:28 AM
91vertZ28's Avatar
ramey
i do not have coilovers. I have stock springs in front and koni sport yellows. Now it may be that the strut nut part maybe came loose again. Its a daily driver. Will get alignment tomorrow and see if they find steering parts issue. The camber plate on the driver side is great no noise. Any insight would appreciate thanks Ramey
Old Jan 22, 2019 | 07:22 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
The nut should not be getting loose, either the locking nut is wire out, or maybe it's not seating all the way. You didn't use the factory strut dust covers did you?
Old Jan 22, 2019 | 07:53 PM
91vertZ28's Avatar
i did not use the dust covers . only the new hardware. I called Koni and asked how much i should torque the strut nut and was told 33 ft/lbs. If the nut gets undone slightly and causes that issue the. New nut will be needed correct? And i found a blog that has info on this issue . could it be what i am experiencing ? Here is the link . http://www.vorshlag.com/forums/showthread.php?t=8474
rwstegne
Aftermarket Product Review
May 26, 2012 09:34 PM
19doug90
Jul 6, 2009 06:51 PM
Josh R
Mar 1, 2009 12:42 PM
Dean-B4C6SPD
Sep 12, 2003 08:52 AM
Mathius
Jun 8, 2003 01:35 PM
