Clunking, crunching sound driving 0-10mph
Old May 31, 2019 | 08:38 PM
Z06 FAN's Avatar
Car: 87 Iroc
Engine: built 355, 450HP
Transmission: built 700r4
I have this cluncking, crunching kinda hollowish sound pulling away or stopping at a traffic light. It also happens pulling in my driveway which is again slow speed. I thought maybe it was my U joint since I replace one of the two last year. But I pulled my driveshaft off and and spun the u joints around to see if it made any sounds and they sounded ok with no noise or resistance. I also noticed my Transmission fluid was down 1/3 of a liter so i'm hoping it's nothing to do with that but i'm thinking not. I also spun my rear wheels and the rear end sounds fine so this all leaves me kind of stumped. Cars a 87 Iroc with around 450-500 hp and transmission was built to handle 500hp by my transmission guy.
Old Jun 1, 2019 | 07:38 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: Clunking, crunching sound driving 0-10mph
Look at the front suspension first; it's likely there's something worn/loose. While you're under there, check your brake pads and caliper mounting hardware.
Regarding that u-joint, if you're going to replace one of them, IMO it makes sense to just replace both while you have the driveshaft out.
Old Jun 1, 2019 | 09:51 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Second that. I'd start with a good look at the wheel bearings and brakes. Also, make sure your K-member bolts are tight. When I got my car, two were backing out.
Old Jun 1, 2019 | 02:26 PM
Roblaza's Avatar
I had the same issue with my 87. I replaced the rear axle bearings and it stopped.
Old Jun 2, 2019 | 04:16 PM
Z06 FAN's Avatar
Car: 87 Iroc
Im going to replace the u joint that wasn't replaced then both will be done. There's probably only 500 to 1000 miles on the replaced one. Im lazy these days and had them both sitting there at the time. And I agree that both should have been changed. Things changed in my life a few years ago that turned me into a lazy individual...lol. I'm going to run the car and see if the noise goes away and if it don't pay closes attention to some of the items mentioned.
sancho
Jul 24, 2013 05:48 PM
RockShowTrader
Jan 28, 2013 04:16 PM
88_Import_Slaye
Apr 8, 2006 10:30 PM
7plagues
Aug 24, 2005 06:18 PM
Scott_92RS
Sep 26, 2002 10:09 AM
