What is this down here?
Old Jun 3, 2019 | 12:45 PM
JonJon5.0's Avatar
Old Jun 3, 2019 | 12:47 PM
JonJon5.0's Avatar
Re: What is this down here?
What kind of socket do I need to use to remove this weird thing that’s holding on my brake rotor All the 3rd gens I worked on never had this I think normally it’s like a 32mm socket and it comes off but in this case idk what this is or what to use to get it off I am not going to use it anymore anyway
Old Jun 3, 2019 | 12:55 PM
Twin_Turbo's Avatar
Remove cotter pin and the indexable retainer. The nut is behind there.
Old Jun 3, 2019 | 12:57 PM
JonJon5.0's Avatar
So u basically just tap it off after the cotter pin is removed or can I use Channel locks to twist it left
Old Jun 3, 2019 | 01:00 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
i've never seen that, but from Twin-Turbo's reply it sounds like it's just a metal cap that sits on top of the nut. once the cotter pin is removed, the metal cap should just pull straight off. then use your socket to remove the spindle nut.
Old Jun 3, 2019 | 01:01 PM
Twin_Turbo's Avatar
You just oull. The thing just slides over tge nut in many available positions hence all the "teeth" just a 12 obt guves a bunch more ootions for clocking on a 6 pnt
Knight350
Sep 5, 2005 11:07 PM
ponykiller
Jan 4, 2005 04:12 AM
94-6spd
Jul 13, 2004 12:16 AM
1986CamaroSC
Jun 27, 2004 02:58 AM
FruityOne
Oct 25, 2003 08:39 AM
