Power steering screech/grind noise at full lock
Hey all. Have a question about a noise I get at full lock left or right. I’ve never heard anything like it on any vehicle. Car has been in storage for a few years now and I’m about to get it back next month. That being said, I know this power steering screech is gonna bug the crap out of me when I do get back to work on it.
My engine is the carb’d 2.8. Running v-belts still. Last thing I remember doing to the car to attempt fixing the noise was replaced PS pump and replaced all my belts.
This is noise isn’t a quiet one either. It turns heads when it happens, so I usually try to be extra mindful and not turn my wheel full lock left or right. It’s not a typical “whine” it’s more of a violent “nails-on-a-chalk board” kind of sound. Anyone ever heard anything like it? No air in system. Never have loss of power steering. Pump doesn’t whine, noise only happens at full left or right lock.
Any my help or suggestions would be greatly appreciated.
Thanks!
black 83 2.8 firebird with factory t-tops
Thanks!
Re: Power steering screech/grind noise at full lock
Sounds like a loose belt; slipping in the pulley when the load is highest.
Try tightening it.
Might even need a new one; "replaced" whenever notwithstanding.
Try tightening it.
Belts are tight. Is there a chance maybe to pulley is not seared all the way? It’s not the same noise as a belt squeal, it’s definitely different
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I'd suggest having your assistant work the steering wheel while you watch the pulley. Instinct tells me it won't be hard to spot.
Car: 1991 Z28 Vert
I am suffering from the exact same problem. That noise at full lock ain't pleasant! It's not belt noise. I also have a rebuilt power steering pump along with a rebuilt steering box and I've always assumed it was something inside the pump like an internal stop or other adjustment that was set incorrectly. Because like you said, everything functions perfectly otherwise.
I’ve done this with several folks, I suppose next time I’ll break out the stethoscope and see if I can pin-point exactly where the noise is. I’m also entertaining the idea of a serpentine conversion in the future. Would you happen to know of any kits for this or is it a trial and error kind of job?
To add to what Sofa said, you MIGHT also be able to connect your timing light and aim the flash at the PS pulley in an attempt to "stop motion" while a helper cranks the steering wheel to full lock. Just be REALLY CAREFUL because the belts and pulleys ARE still rotating!
mrsupermexican
Aug 19, 2011 05:42 PM
Randy82WS7
Aug 6, 2002 02:38 PM
1BadGTA
Jun 11, 2002 09:01 AM
