Sway/Stabilizer bar diameter
Old Jun 30, 2019 | 06:30 PM
jamesv's Avatar
Car: 1987 Chevrolet IROC-Z Camaro
Engine: LB9 > L98 5.7-liter V-8 TPI
Transmission: MD8 4-Speed Automatic MX0
Axle/Gears: GU5 3.23 G92
Is the diameter of the sway bar and stabilizer bar on my 87 Camaro stamped somewhere on the bars? I'm wanting to order new bushings but don't know what diameter to order.
Thank you in advance,
James
Old Jun 30, 2019 | 07:48 PM
Drew's Avatar
Re: Sway/Stabilizer bar diameter
No, there's probably a stamp here or there, but the only mark that tells what they are was a paper tag from the factory. If the car has been driven much since new, the tag is probably long gone.
Option 1 ) Grab a big adjustable wrench, slip the open end over the bar and tighten the wrench as far as you can, then measure the distance between the jaws of the wrench.
Option 2 ) Use a caliper.
It'll be metric, for what it's worth.
Old Jul 2, 2019 | 11:38 PM
McLovin1181's Avatar
Measure it with a pair of calipers.
If you don't have any, buy a $10 set at Harbor freight.
The cheap ones are VERY useful when working on cars.
Also consider buying bushings that have grease-able fittings on them.
Some do not have fittings, and Poly stuff will squeak of it's not lubed up.
(Yes I know HF stuff is probably +-0.002 tolerance)
allaneyre
Aug 26, 2012 10:52 PM
Steven6282
Mar 23, 2012 02:19 AM
mw66nova
Jan 12, 2006 03:58 PM
89FormulaRoth
Nov 21, 2001 04:13 PM
84IROC
Nov 16, 2000 10:06 AM
