Front End Vibration at Highway Speeds
Old Jul 12, 2019 | 06:56 PM
marknva's Avatar
I have a '84 Camaro with stock 14" wheels. Around 65 MPH i get front end vibration that shakes the steering wheel. Tends to smooth out at higher speeds, my tire wear is even could my sub frame be out of alignment?
Old Jul 12, 2019 | 07:12 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Re: Front End Vibration at Highway Speeds
No, my first bet would be an imbalanced wheel.
Old Jul 12, 2019 | 11:22 PM
That, or a farkled tire. (that's a technical term...)
Swap your rear tires to the front and see if it clears up. If so, it's a wheel/tire problem. Swap em back one at a time; when the problem returns, that's yer answer.
Don't outsmart yerself. It's just a car. Doesn't get much simpler. Use logic and common sense, and you will almost always be rewarded instantly with truth.
Old Jul 13, 2019 | 11:16 AM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
Axle/Gears: 10 Bolt 3.73, Torsen Diff
If moving tires around doesn't clean it up, it might be the rotors. Do you get any pulsing when you hit the brakes?
The_Wraith
May 27, 2013 10:23 PM
90_WS6_Formula
Dec 7, 2006 08:41 AM
breathment
Oct 5, 2002 03:10 AM
EDGE
Sep 9, 2001 09:59 PM
MatchboxTransAm
Oct 18, 2000 10:18 PM
