Big Crack
Old Jan 11, 2002 | 02:43 PM
JungleJim's Avatar
Big Crack
I found a LARGE crack in the "frame" right behind the Steering box on my '85 Camaro......Anyone have this happen before?
Old Jan 11, 2002 | 06:37 PM
ede's Avatar
ede
it's very common, weld it up , a wonder bar would help prevent it from happening again.
Old Jan 11, 2002 | 10:27 PM
CrazyRob75's Avatar
yup ihad this problem on mine. i had a "FEW" cracks. frt. end was all sloppy, frame would pop on slow turns in a parking lot. i welded the cracks, then put a few gussets on it, AND added a wonder bar. All is good now even with the 454 in there. Just to give you an idication of how bad mine was, i could grab the dr. frame railwith my hand (with the car in the air) and wiggle it back and forth easily.
Old Jan 12, 2002 | 05:06 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
If you weld the (these) cracks up with a MIG welder. Then you can grind them down flush and you will never even see them.
Old Jan 12, 2002 | 07:37 AM
JungleJim's Avatar
Thanks Guys
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
redformula88
Oct 14, 2015 06:08 PM
codeysabatini
Sep 20, 2015 11:36 AM
gta892000
Sep 16, 2015 12:37 AM
ronchic
Mid-Atlantic Region
Sep 15, 2015 08:04 PM
