Help with steering play
Old Sep 19, 2019 | 01:11 PM
BigWhiteK2500's Avatar
In my 84 z28, when driving around town at low speeds the steering is tight and smooth. But when i get up to highways speeds i have to hold the steering wheel at the 10 oclock position in order to keep going straight and i get a small amount of vibration. I bought the car about 4 years ago and never had this problem until the start of this summer. Tie rods, ball joints, idler and pitman arm look in good condition so im thinking it's either the rag joint or steering box. Anyone have any advice, i'd really appreciate it.
Old Sep 19, 2019 | 01:58 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Re: Help with steering play
It's usually the steering box, but a astro shaft steering shaft upgrade can help a bit.
You can grab the bottom of the steering shaft with a vice grip and have someone turn the wheel and feel the play by hand. Probably some but not much there.
You can then see the play in the steering box by turning the steering wheel side to side, and any amount that the steering shaft turns but the wheels dont.. that's slop in the steering box.
Lares does a nice reman on steering boxes. You can even send your box in to them to have remaned.
Old Sep 21, 2019 | 01:28 AM
McLovin1181's Avatar
1. Rebuild linkage
2. Install Astro shaft
3. Get a professionally built steering box
4. Use the proper alignment specs, not the factory garbage.
Old Sep 21, 2019 | 01:32 PM
10:00 I'm going to assume means you have to turn it to the left about 60°?
And you have a vibe? Tire vibe I'm going to guess?
A separated tire can cause both of those symptoms. Try swapping your front tires side to side. If you suddenly have to hold the wheel at 2:00, you just found your problem; and it isn't the steering.
I'm also going to assume (yeah I know, but it's all I can do at the moment) that you already had your assistant sit in the car and shake the wheel side to side while you got up under it and looked for play and lost motion. That of course, being the VERY FIRST THING any sensible person would do when … looking for play and lost motion. And furthermore that everything is all tight and that whenever the upper steering shaft reversed its turning direction that the tires immediately started turning, and nothing moved inside of anything else or anything like that.
Old Sep 21, 2019 | 06:25 PM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Originally Posted by McLovin1181
1. Rebuild linkage
https://m.youtube.com/watch?v=1nFJRU2bK6g
your video (I think) has an error in it. I asked you a while back about it, but never heard back. was trying to get some clarification. forget what it was. check your original post for my question.
Old Sep 22, 2019 | 12:29 AM
I listed the wrong part number for the idler arm.
The correct one is the AC Delco.
Moog idler=junk
thegoochking
Nov 12, 2016 08:52 PM
kcallais
Feb 10, 2009 11:40 AM
sesand
Nov 3, 2008 09:02 PM
F5Storm91
Mar 5, 2005 10:16 PM
Karps TA
Jun 20, 2002 09:10 PM
