New BMR caster camber plates
Old Oct 9, 2019 | 05:34 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
Anyone see these yet? Seems like they just announced them. Look simaler to the Detroit Speed ones.
https://m.facebook.com/BMRSuspensionInc/photos/a.177736262244053/3465686020115711/?type=3&source=48
Old Oct 10, 2019 | 07:13 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: New BMR caster camber plates
So....you can only adjust these one tooth at a time? Finer adjustments would not be possible? Any idea how degrees of adjustment one gets by moving one tooth?
Old Oct 11, 2019 | 08:47 PM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
how much? I like 'em….
Old May 8, 2021 | 07:04 PM
MI ROC-Z's Avatar
Car: 89 IROC-Z
Engine: L98 5.7 liter
Transmission: TH700r4
Axle/Gears: limited slip 3.23
They're garbage. I got them the other day, tried installing them today and the tolerances are wacked out.
Old May 8, 2021 | 07:12 PM
NoEmissions84TA's Avatar
They look like a solution to a problem where there never was one to begin with.
Old May 10, 2021 | 06:42 AM
ratsnotmice's Avatar
Car: 1989 IROCZ
Engine: LS2
Transmission: TH350
Axle/Gears: Moser 9in 3.70 Trac lock
Can you provide details? I'm sure many of us are interested in the specifics about the fit and finish of this product. Any idea how it compares to the Detroit Speed version?
Old May 12, 2021 | 07:47 AM
Yeesh's Avatar
I installed these in my '91.
I had two issues :
- BMR shipped the wrong hardware and I destroyed the threads on the bearing mount that holds the top of the shock. They quickly shipped me the correct hardware and a new bearing mount.
- When I torqued down the nut on the top of the shock, the bearing was bound up and the whole wheel well would flex when I moved the wheels side to side. The issue was the plastic shock cover (Koni Yellow) was causing it to bind. For now I have removed the shock cover and it's all good.
I did not have any issues with the tolerances being "wacked out". It's possible the other poster was trying to mount them on the wrong side of the car. The directions were not super clear and that's what I almost did. The holes would kind of line up but you could tell it wasn't right.
I have not driven the car yet.
Old May 25, 2021 | 02:57 PM
Yeesh's Avatar
Just a quick update :
I dropped my car off to get an alignment last week and a few other things. I told the guy "no rush".
I called today to see how he was doing and he said he spent almost 2 days trying to get it aligned (hyperbole?) and had to step back because he was frustrated. He said the little retainers are very very difficult to work with while the suspension is loaded up. He hasn't given up on them yet, but the initial review is not good.
Alternatives?
Old May 26, 2021 | 01:22 AM
Again, they look like a solution to a problem where there never was one to begin with.
Jesuslove7
Aug 8, 2016 12:46 PM
dbrochard
Jan 18, 2016 02:47 PM
EatFordShtDodge
Northern California
Feb 13, 2007 11:03 AM
91_5.7_TPI
Jan 4, 2007 08:41 PM
INTIMIDATOR Z
Mar 11, 2006 03:01 PM
