5th gen electric power steering in 3rd gen
Old Dec 8, 2019 | 09:22 PM
Terence Zelman's Avatar
Car: 1987 Iroc Z
Engine: 5.7
Transmission: 4 speed auto
I have a complete 2015 Camaro ZL1 as a donor car for my 87 Iroc. What do you guys think about converting the iroc to the electric power steering setup?
Old Dec 8, 2019 | 10:05 PM
DIGGLER's Avatar
Re: 5th gen electric power steering in 3rd gen
i donno, but im all ears!
Old Dec 8, 2019 | 10:07 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Are you doing the power steering swap to save weight? Save power?
Old Dec 9, 2019 | 06:30 AM
Car: 1987 Iroc Z
Engine: 5.7
Was just thinking it may be easy enough vs adding a power steering pump and there seems to be some benefit to it. I have the entire car so I am just considering hat I should keep and what I should ditch.
Old Dec 9, 2019 | 08:42 AM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
How did you happen to get a 2015 ZL-1 for a parts car?...
Old Dec 9, 2019 | 09:45 AM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
If I were in your shoes, I would make the attempt to convert it. In the long run it will be less things that have to be deleted out of the programming. It'll probably be an overall easier package as well instead of having fitment issues with the LS engine accessories and the steering gear box.
Old Dec 9, 2019 | 09:54 AM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
Depends on if the rack is in front or behind the k member. You my find that you have to do some heavy Fab work to do the swap. You can check out the thread on putting a C4 k member on a 3rd gen for some ideas.
Old Dec 9, 2019 | 01:58 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
There is a guy that made a control box to convert Cobalt SS and G6 EPAS for use in kit cars. Not sure how it would apply to the Camaro EPAS. But I remember it was interfaced with the steering column itself, and not the steering gear.
Old Dec 9, 2019 | 08:05 PM
Car: 1987 Iroc Z
Engine: 5.7
it was a write off at a local auto wreckers so I bought it. Only has 13,000km on it. 👌🏻
Old Dec 9, 2019 | 08:09 PM
Car: 1987 Iroc Z
Engine: 5.7
I am hoping there isn’t a ton to it. I have absolutely everything less a few lights and smashed up body panels so it will be nice to see it come off one car and onto the next.
Old Dec 9, 2019 | 08:10 PM
Car: 1987 Iroc Z
Engine: 5.7
I just got a price on a heidts crossmember and full suspension including IRS. hoping that gives me more mounting room up front.
Old Dec 13, 2019 | 11:43 AM
McLovin1181's Avatar
You can make is happen, but it will work like complete garbage.
3rd gens use Long arm MCStrut suspension.
5th gens use a short arm MCStrut suspension.
Modern Racks arnt wide enough for our cars.
the end links end up being like 24in+
you will end up with a bump steering monster.
Not to mention the ratio is 16:1, so that's SLOW compared to the 3rd Gen Z box at 12.7:1
You can easily use the 5th Gen LSA and brakes.
The tr6060 will need a different tailshaft.
Or if it's a 6 speed auto, y'all gonna have to do some hammering to get it to fit in our 3rd Gen tunnels.
Answer?
It's not worth doing all that work for a crappy setup steering.
Rebuild the stock linkage
Get a name brand rebuilt Box ($300+)
Use a proper alignmealignment.
bump steer kit if needed
those will get you the nicest steering a 3rd Gen can accomplish.
Old Jan 6, 2020 | 06:40 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
Answer?
agreed, i send that
Hawgtied
Mar 13, 2019 11:36 PM
383 Power
Apr 1, 2011 08:17 PM
84 Challenge
Mar 12, 2003 10:12 PM
