Lowering versus stock
Old Apr 13, 2020 | 05:56 PM
erik69&85's Avatar
i don't know if anyone else has had the same experience......
I have owned 2 cars with stock suspension... 85Z and 89 IROC... both cars handled and turned beautifully.... could carve canyons with those...
Bought my 92Z with a previously lowered suspension.. about 1 inch... but this car has never felt as good... (Looks killer) I have done a lot to try to fix this....
- Totally rebuilt front end equipment.. new A-arms, bushings, sway bar, wonder bar
- Went through 3 different steering boxes.. 2 rebuilt, 1 upgraded new
- New power steering pump
- wears front tires like there is no tomorrow... maybe 10k miles
- had the front end re-aligned twice
- tried 2 different tires
- grind tires on body at full lock
Just can't get the car to drive and feel as good with 1 inch lowering springs as the others do with stock geometry.... in 8 years I have never figured this out.. guess i will stay stock height in the future...
Old Apr 13, 2020 | 06:24 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
Re: Lowering versus stock
You did not mention which lowering springs you are running.
I have had great luck with my Eibach Pro kit and can completely tell the difference from stock springs as far as the stiffness. I would go back and double check your camber/camber plates for broken rubber if still stock. Also have the alignment done and check there numbers as some shops don't use a computer alignment machine. You shouldn't be going thru front tires like that if all the suspension is in good condition, that's the give away sign to your handling problems
Old Apr 14, 2020 | 07:09 AM
erik69&85's Avatar
I wish i knew what springs were in there but they were done by a previous owner... at least 2 owners and 15 years ago...
Both alignments were done by the best tire shop in town and they use a computer alignment system... i have the printouts...
I have to get new tires to pass NYS safety inspection so i will have it done...again....
The ONLY thing not replaced has been the plates.... something ... probably the only thing i have never done on third gen suspension... I hear mixed reviews on the aftermarket ones...
Old Apr 14, 2020 | 09:17 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
I agree with 85. Springs and dampers make all the difference. I have Bilsteins and UMI springs and it looks great, rides great, and handles great - much better than my stock setup which was not/could not be OEM. I tried the KYB and Moog springs for my stock setup and was not very happy with it.
Old Apr 14, 2020 | 06:14 PM
erik69&85's Avatar
I had kyb adjustables on the 85 with stock springs and I was very happy with it... Now I have kyb adjustables with unknown lowering springs and it just doesn't feel great ...at least not the steering.
Old Apr 14, 2020 | 08:31 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
I have Eibach Pro Kit on my 91 TA and love them. If I am not mistaken the name is listed on the springs but I think it is a German made spring? The last time I had an alignment the guy under the car said that they were German and I know that they were Eibach because I ordered them and installed them. Hope that helps.
Old Apr 15, 2020 | 07:06 AM
erik69&85's Avatar
Has anyone made changes to their steering from stock... or changes to their alignment specs?
closer
Feb 24, 2016 07:49 AM
Rob1991
Jun 20, 2014 07:38 PM
hotrodhaskins
Fabrication
19
Jan 29, 2007 04:03 PM
Rons91Bird
Feb 17, 2005 02:44 PM
