BMR Coilover Conversion?
Old May 29, 2020 | 05:47 PM
BrianI's Avatar
Thoughts on this? Seems pricey without struts?
Old Jun 2, 2020 | 04:02 AM
alan91z28's Avatar
COTM Editor
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
Re: BMR Coilover Conversion?
i originally utilized the BMR coil over suspension in my 85 IROC LS conversion back in 2009. It was well made and seemed to work well. I ended up being worried about long term is the shock tower really capable of handling the load and have gone back to front springs utilizing UMI weight jack set up
Old Jun 2, 2020 | 07:52 AM
BrianI's Avatar
Did you have any noise with the coilovers or the weight Jack's? I've looked at those as well. Do you drag race at all? I plan on taking my car to track and thats the reason for leaning toward the coilovers but it's a 95 percent street car.
Old Jun 2, 2020 | 08:41 AM
BrianI's Avatar
Double Post
Old Jun 5, 2020 | 12:20 AM
eflores's Avatar
Car: 91 z Clone
Engine: 6.4l LSX
Axle/Gears: s12 3.73
following
Old Oct 12, 2020 | 03:14 PM
BrianI's Avatar
I installed the BMR coilovers on the front with Lakewood struts. I was hoping it would lower it more as the pic below is at the lowest setting. I modified the lower spring perch to get it down some more. I have since raised the rear up so that it sits level now.
At the lowest setting as purchased:
Modified spring perch:
Old Oct 13, 2020 | 12:00 AM
2slow5.0's Avatar
Car: 91 Formula
Engine: 5.0 tpi slow
Transmission: WC t-5
Dang. Car is seczee. Did you do a build thread on it? Paint really pops on it
Old Oct 15, 2020 | 07:20 PM
BrianI's Avatar
Thanks!! I had intentions of doing a build thread but it didn't happen. I still need to finish the wiring for the wiper motor and install cruise control.
soloz
Oct 19, 2019 06:55 PM
Willie B.
Dec 22, 2017 06:26 PM
85SILVERBULLET1
19
Jun 6, 2014 03:13 PM
88gta3508
Mar 12, 2012 01:35 PM
