Front alignment problem, all new... caster problem !
Old Jun 2, 2020 | 02:32 PM
adelane's Avatar
Hello,
I need your help.
I have a 86 trans am, I did my front alignment with my original setup, it was bad :
- left : -0.5 camber ; 3 degrees caster... I can't have better, I can't put adjuster more on the rear... the maximum caster I can have...
- right : -0.5 camber ; 4.5 caster,.... Adjuster at the maximum toward the front... the minimum caster I can have...
So I think... everythink is gone, I buy new a arms from BMR, and new caster plates.
I change everyhting...
And it is not really better :
what can I do ?
Do I have to change the brace which supports the engine and the two control arms ?
Thanks for your help
Marc
Old Jun 2, 2020 | 05:21 PM
Re: Front alignment problem, all new... caster problem !
No; you need to elongate the slots that restrict the rearward movement of the strut, with a file or die grinder.
Moving the strut rearward increases positive caster. To get from 3 to 4.5 or whatever, it needs to go rearward.
Might not be a bad idea to verify that your left spindle is not bent.
Old Jun 3, 2020 | 04:05 AM
adelane's Avatar
Hello,
I understand your point of enlongate the slots, but there is not a lot possible, maybe 1/8" which would not be enough...
But what I don't understand is why on the right I can't have less than 4.5 degrees caster, as minimum, caster plate full on the front.... and the left is totaly the inverse, I can't have more than 3 degrees... none of the two sides can't have a standard caster.... this l
The two spindles are two new ones (I think refurbished) from baer brakes which came with my front brakes. I juste installed them before doing the first alignment with the old a arms.
It's like my front axle (or K member) would not be perpendicular to the body.
thanks for your help
Marc
Old Jun 6, 2020 | 12:19 AM
83 Crossfire TA's Avatar
How about figuring out what's bent/screwed up before throwing any more parts at it?
Old Jul 23, 2020 | 12:22 PM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
An old vintage car mechanic restorer used to say that the bodies deform over the years.
Also, if the car had a crash, the deformation has already occurred.
Normally, in an alignment workshop, the computerized machine detects the deformationof the front axle system.
Then, start with "what's bent/screwed up"
Old Jul 23, 2020 | 04:17 PM
z28cp's Avatar
Check the alignment of the K-member.
hellz_wings
Sep 8, 2010 07:09 AM
dust3r
Aug 27, 2010 06:37 PM
qytum
Jul 22, 2010 05:00 PM
hellz_wings
May 21, 2010 03:46 PM
bjm323
Sep 13, 2003 09:23 AM
