New master cylinder and front pads= no driving side braking
Old Jan 14, 2002 | 04:29 PM
5 litre eater's Avatar
Car: '84 Trans Am
Engine: 350ci Sportsman heads, B&M blower
Transmission: Turbo 350
Like I said.I started to bleed my front driver side brake and nothing happened. You could pump the pedal and no fluid would come out and no air gets sucked in.I took the flex line off of the caliper and the same thing.Do I need a new hard line???Is there something plugging it maybe?.Please help, I need be driving in about 1 hour.
Old Jan 15, 2002 | 05:01 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Replace the brake hose first.
Old Jan 15, 2002 | 08:43 AM
TVP's Avatar
TVP
did you bench bleed the master cylinder ??? I always let a gravity bleed run for awhile before using any other method
TVP
Old Jan 15, 2002 | 12:10 PM
Car: '84 Trans Am
Thanx guys but I got it sorted.The flex line collasped,I couldn't blow 110 psi through it so I replaced it and the brakes are now great.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
