Flex in aftermarket camber/caster plate?
I’m working with the vendor who has had great communication so far but I thought someone else may have run into this or something similar before.
This is what happens when I swing the spindle from left to right.
This video is with the nut torqued down (50ftlbs)
https://streamable.com/g2g7du
if I remove the nut there is zero binding. No flex in the plate but the shock shaft does move up and down a bit in the bearing.
https://streamable.com/xoz38b
Re: Flex in aftermarket camber/caster plate?
Do you have the plastic sleeve on the shock?
Remove them. Look for my thread abput my 82 ta 87 iroc or gerrutcamaros car. I showed how to install a koni bumpstop and rancho boots to do away with the plastic sleeve
https://www.thirdgen.org/forums/susp...ml#post5984765
Thanks TT. Linked your post in case anyone else needs it as well.
Axle/Gears: 10 Bolt 2.73 Open
I haven’t had it on the road yet, just getting it together. I haven’t verified, but it seems like the shock shaft cover is causing the bearing to bind up. I’m hoping I can modify the cover to move it an inch or so down the shaft to fix the issue. I will update the thread when I fix it.
Thanks. I read the linked threads from Twin Turbo.
Hard to believe that flimsy little plastic dust cover can create the kind of pressure it would take to flex that whole mount, without destroying itself within a few turns.
I'm probably missing something basic here.
The cover has a pretty thick steel washer up.top
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
That's right. There are NO aftermarket designed strut mounts that will work with the plastic covers the new struts come with. I completely forgot about that.
