Bilstein bolt size
Old Aug 2, 2020 | 01:57 PM
Ironmike77's Avatar
Bilstein bolt size
Hey guys have a question. Anyone know the size of the bottom bolt for the Bilstein shocks? I ended up stripping the bolt, and would like to rethread it. What size die should I buy for it? Thanks.
Old Aug 2, 2020 | 05:44 PM
NoEmissions84TA's Avatar
Re: Bilstein bolt size
Why? The threading die probably costs 10x the price of a new bolt.
Old Aug 2, 2020 | 05:50 PM
Ironmike77's Avatar
Because I don’t think the bolt comes out? Isn’t it all one piece? And pressed in with that metal backing?
Or can I knock that loose. Well either way what would be the best solution? Because I would hate to have to buy two new shocks.
Old Aug 2, 2020 | 06:30 PM
I can't say if this is the correct size, but will this work?
https://shop.advanceautoparts.com/p/...E&gclsrc=aw.ds
Old Aug 2, 2020 | 06:39 PM
Ironmike77's Avatar
Not sure, but something like that could work. I could just knock the old one out. I’m kind of new to doing this work by myself. So I’ve been learning with mistakes I make. And I know one thing for sure. I’m never using an impact gun to tighten. I’m using it to just loosen from now on.
Old Aug 3, 2020 | 09:49 AM
Shock hardware is EXTREMELY standardized. The particular bolts and whatnot that a particular mfr uses might look different from others, but once you take all that out, that round place that the bushing goes in, is the same as any other brand. Makes it SOOOOOOOPER EEEEEEEEEEZZZZZZZZZY to just go to the store and get new instead of having to dink with abuncha rusted stripped funkified old garbage.
fullsize fun
May 12, 2017 09:14 AM
alacran
Nov 15, 2010 08:37 AM
86Z
Mar 17, 2008 07:12 PM
King Nothing
Jul 28, 2004 11:57 AM
mcconahay37
Dec 26, 2001 04:50 PM
