subframe connector exhaust clearance.
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
i am looking at getting subframe connectors for my camaro and it looks like i might have a problem with the exhaust on the pass side.
i know this has probably been covered a million times, but does anyone have pics of their pass side exhaust routing and subframe connectors clearance.
i cannot possibly see how i would make them fit.
ill post pics when i get a chance, but its cold as ***** out now.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: subframe connector exhaust clearance.
what SFC are you looking at? most of them step up at that point and the exhaust goes under the SFC. Some styles will not work with the stock style exhaust.
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
My UMI sfc is about an 1/8" away from hitting. I'm going to have to put a piece of header wrap between the Y and SFC to keep it from vibrating.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
No problems with my Global West SFC's and Hooker Y:
https://www.thirdgen.org/forums/atta...please-cat.jpg
JamesC
JamesC
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
I just finished mine and exhaust clearance was my biggest concern. I used 1-1/2" sq. x 1/8" tubing and I have a 4" thick Magnaflow muffler where the cat used to be. I removed the sheet metal cat heat guard so I could mount the tubing as close to the floor pan as possible. I ended up with at least 1/2" clearance between the two, so I am happy.
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
I know its an old thread but I didn't want to start a new one.
Currently doing my exhaust and wanted to know just how much clearance I need to keep between the subframe connector and exhaust?
Note: I just replaced my motor mounts with prothane poly's so the engine sits a good 1/2" higher now - thus the reason I'm re-doing my exhaust.
I had 1/8" of clearance on mine, sitting still with the engine off. Sitting still idling (with a some cam chop) it would intermittently hit. Readjusted to about 1/4" and all was well. Obviously different set ups and different places along the exhaust will be more prone to movement, but typically most of us seem to have issues right there behind the rear wheel/cat area.
Hotrodboba400
Dec 10, 2019 07:07 PM
