Jack stand location
Jack stand location
Ok, I know this has been asked before. But I have some questions. I’m swapping out my rear end. But I need to know where to put jack stands on the rear. I read where the LCA’s mount to. So I would take out the LCA first, then put the jack stands where they mount to? I’ve had had bad luck in the past and ended up denting the hell out of the bottom. Are those mounting brackets sturdy enough to support the car and jack stands for a long period of time?
Re: Jack stand location
That is correct. Put them under the thick flat thing just in front (like about 1") of the LCA bolts. Yes it is plenty strong enough to support the car's weight. You can support the car there before you remove the bolts.
I STONGLY suggest putting the front up on stands as well, so that the car is stable, and more nearly level. A good place on the front is under the spring pockets of the front CAs or under the part of the K-member where the front bolts for the CAs go through it.
I gave up already lol. I had just installed new shocks and springs a few months ago. The damn bottom nut for the shock just keeps spinning and won’t loosen. They’re Bilstein shocks. With this car, it just seems like nothing can just go smooth the way it’s supposed to.
Wizz wheel it and get a new one. Maybe a can of the copper anti-seize at the same time.
Life is too short to put up with crap like that.
Car: '89 Firebird
Engine: 7.0L
Jack stands (at least the kind I've owned) have angled perches that don't spread load on flat surfaces under the car. My experience is a jack stand will eventually deform any of the sub-frame components under the car. My car has spent a LOT of time on jack stands over the years and the underside shows it. It don't bother me. But if it bothers you then be forewarned.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Be careful of the pinch weld on these cars. 99% of these cars have the pinch weld folded over and or beat up. Quick is correct about jack stands messing up the bottoms of these cars. The control arms are a great place to help even out the load of a jack stand. Better yet, get some subframe connectors and you'll have the best surface for jack stands.
Thanks for all the input guys! Yeah I can tell by the pinch welds on mine. Some areas are all folded over! A lot of areas you can see where someone tried jacking up the car and totally messing it up! But yes, by far the only place I feel safe is right there by the LCA. I had the weight of the car sitting on it. And it held up great. But then like I said, I couldn’t get the nut of the shock. And I don’t own an angle grinder or any type of electrical saw. So I couldn’t cut it off.
I’m going by a buddy tomorrow to get it cut off. It amazes me all the weak points on the bottom of these cars!
Car: 1991 Trans Am convertible
SFCS are truly the best. You get all the benefits of a tighter, better handling car plus you can jack up the whole side of the car along the SFCS if you want.
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Alot depends on the part of the country you are in. I am in SoFlo and it cost me $100 a few years back. I went to a muffler shop that used a drive on lift and they taped and painted over the welds when finished.
Axle/Gears: 10 Bolt 2.73 Open
I've only sought one quote here in metro-Detroit, and it was $250, with me removing all the carpet and trim.
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Well, the floor pan has a chance of getting pretty warm in the areas they are welding. You don't want any nasty surprises.
I've seen people just remove the edge trim and seats, and "lift" the carpet up in the air...prop it up with an old coffee can or something....then when the floor is cool, put it back down. But heck, if I've already got the trim and seats out, why not just pull it? It's a great excuse to access and deal with any floor issues, look for a build sheet, and really thoroughly scrub the carpet. But that's just me.
If I left it for them to do, I'd have to pay them for their time, and trust them to do it carefully. This was a race shop, and I didn't get the feeling they sweated a lot over breaking 30+ year old plastic trim in cruisers and show cars. That may not have been a fair assessment, but I've already had two "good" shops damage the car in the 6 years I've owned it. I simply have run out of "trust" where the T/A is concerned.
Car: 1991 Z28
The shop that did mine did not remove my seats or carpet. He did a "stitch" type weld so he said it would not over heat the floor. There were no burns or any issues when he finished. I will admit I was a little concerned but the shop owner (a friend of a friend) assured me there would be no issue and he was right. I used the Alston style so there was 4 points of contact to be welded.
Yes, I was going to hire out the welding. But I'll take care of the prep, and finishing over those welds when I get the car home.
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
dbrochard
May 2, 2016 06:57 PM
1991Formula350
Nov 15, 2006 11:18 AM
grafx
Feb 1, 2002 07:25 PM
That was my plan.
