Which subframe connectors have the most contact area?
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Looking to stiffen up my crusty ride. Which SFC's tie the most points together?
Thinking about the Detroit Speed ones as they look the beefiest.
Thoughts?
Thoughts?
Car: 88 gta
Engine: 5.8
Axle/Gears: 3.73 POSI
Re: Which subframe connectors have the most contact area?
you want something like this https://swracecars.com/product/82-92...me-connectors/
Car: '89 Firebird
Engine: 7.0L
Detroit Speed hands down, but it's quite invasive and you better have metal fab skills.
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Whoa, just looked at the install for those Detroit Speed ones... holy hell haha.
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
The Spohn weld-in are very good and not invasive. The welding up can cost a few hundred. The SFC's MUST be installed while the car is sitting normally on its four wheels.
Car: '89 Firebird
Engine: 7.0L
Engine: 5.7 L98
The UMI's are pretty solid and non invasive, however if you have a aftermarket/larger exhaust there will be slight modifications to get them installed but that's the case with most out there it seems.
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I didn't think it was a big deal really. I only had a problem in one area on my car where the sheet metal was a little thin from some rust. I kept blowing holes in about a 1.5" section
The instructions are REALLY good, plus they have installation videos. You're really only cutting a long thin rectang out of the car on each side, drivers side moreso than the passenger.
Axle/Gears: 10 Bolt 2.73 Open
The Mopar guys have been installing through-the-floor braces like that in their uni-body cars for a long time. Makes for a very solid connection.
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
I have the S&W setup under my car, mine was put in about 9 years ago. They used to offer two "out-rigger" bars that spanned out about 10" off of each main bar, and these bars tied/bolted directly to the side-rocker panel under our cars. for sure they are on my car but I don't see them in that S&W website photo.
Car: 82 Transam
Engine: 305 soon 383
Transmission: auto.
You mean this one?
Link : SWRacecars
Car: 1987 IROC-Z
You mean this one?
Link : SWRacecars
Link : SWRacecars
yup, thats it, thats hte one I have. the outriggers are a nice easy place to put the floorjack and jack the whole side of the car up at one time. teh exhaust routing for my 3" exhaust is tight, but it works. car is solid. getting a 6 point S&W roll bar installed too this winter and S&W is top notch stuff.
Dholland17
Jun 30, 2020 12:47 PM
