What is this part and its relevance
Old Jan 4, 2021 | 09:33 PM
Magik's Avatar
Car: 91 camaro rs
Engine: 350 Police tbi
Axle/Gears: 12 bolt 373 posi
Trying get my rear end centered. I was looking under the car and discovered this was missing.
Old Jan 4, 2021 | 09:57 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: What is this part and its relevance
I sent the panhard missing too ?
Old Jan 4, 2021 | 11:05 PM
Magik's Avatar
Car: 91 camaro rs
No it has the panhard bar.
Old Jan 4, 2021 | 11:09 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
The part circled is the panhard brace bar. The panhard upper bracket will eventually break off the car without it.
Old Jan 5, 2021 | 09:21 AM
It's called "panhard brace" but it's really a stiffener for the unibody.
Without it, there's nothing but the sheet metal up there, for the panhard bar to bolt to.
Without it, not only will the bracket that's spot-welded to the sheet metal probably break off (and/or the sheet metal itself), but the whole car will/does feel like a limp wet overcooked noodle back there, because there's nothing back there keeping the body (floor pan) in the right shape but the tinfoil it's made out of.
Probably the easiest way to get one is to find somebody on the Classifieds on this site that's parting out a car. Have em provide the bolts for it too, if they can (they're famous for rusting solid in place and having to be wizz-wheeled off).
Old Jan 5, 2021 | 09:46 AM
WTR388's Avatar
Car: 87 Trans Am
Should be easy to find that part locally... I literally tossed mine in my scrap metal pile when I got my founders unit... Which, I would suggest as it allows bigger exhaust back there. Easy to install and cheap.
Old Jan 5, 2021 | 10:24 AM
Magik's Avatar
Car: 91 camaro rs
Thanks gentlemen! There are a couple third gens at the pull n pay here i can pick one up for about 10 bucks.
Couldn't figure out why it felt so sloppy still after I adjusted the pinon angle.
LB9GTA
Oct 3, 2020 08:25 AM
raaneal
Canadian Region
Feb 5, 2017 08:45 AM
KNIGHTE
Jun 30, 2015 12:58 PM
Yahtzee
Jan 28, 2010 03:00 AM
devianb
Jan 2, 2004 11:15 PM
