Aftermarket Sway Bar
Old Mar 6, 2021 | 08:01 PM
Jenkins's Avatar
Car: 1984 Trans Am
Engine: Lg4
Axle/Gears: 3:23
As the pick & pulls are stocking few third gens, it seems the choice is either used or new aftermarket. The used ones are no longer a cheap alternative, once shipping charges and new bushings are added. When I search for hollow front bar, it seems the choice is Spohn. What's the best option for a weekend cruiser? My car is a most stock 84 Trans Am, though I am running 245/50/16s.
Old Mar 7, 2021 | 05:14 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
Re: Aftermarket Sway Bar
Got to ask what is wrong with your stock bar? And do you know what mm it measures?
Old Mar 7, 2021 | 07:04 PM
Jenkins's Avatar
Car: 1984 Trans Am
Engine: Lg4
Axle/Gears: 3:23
It’s the stock 32mm bar. It needs new bushings and end links. I have a 24mm rear bar from a previous project. I planned on installing the rear bar and since mine needs bushings I figured might as well upgrade the front bar. We have a stock WS6 86 Trans Am that handles much better than the 84. I’d like to have that same level of handling.
Old Mar 7, 2021 | 08:15 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
The 86 might have a 34mm bar but I’m wondering if it has a touch better spring set in it also. Hawks sells a decent front bar they call it a 36mm but it’s a gm 34mm I have it now going to be selling it soon but another issue is they sell the wrong bushing mounts with it also so they can work just need to drill a hole for the offset mounting.
https://www.hawksmotorsports.com/82-...rcoated-black/
Old Mar 7, 2021 | 11:37 PM
Jenkins's Avatar
Car: 1984 Trans Am
Engine: Lg4
Axle/Gears: 3:23
I looked at that one. That’s pricey for a used bar. I realize it’s powder coated but over $200 dollars, that’s new bar pricing. Why do they claim a 34mm bar is 36? I see Summit sells a QA1 35mm bar with bushings for around $250. Not familiar with QA1. Doesn’t have bad reviews
sonu1975
Apr 10, 2017 10:31 PM
-LateNite89-
Nov 25, 2011 01:32 PM
FullSendRacing
Nov 22, 2011 08:50 PM
92blue
Jun 15, 2002 03:07 PM
