lift bars
Old Jan 16, 2002 | 11:53 PM
PimpCamaroRS's Avatar
lift bars
what are lift bars an has any one got any comments if they are worth getting?
Old Jan 17, 2002 | 01:44 PM
Tas's Avatar
Tas
Those are mainly for leaf sprun cars. It takes the twisting action that the axle exibits on the springs and stops it with bumpstops. The spring twists about an inch and then the lift bar pushes up on the front of the spring eye. This in turn forces the axle down and giving the tires traction. Cars without torque arms like ours can benefit a lot from these.
Old Jan 20, 2002 | 08:46 PM
ATOMonkey's Avatar
Since lift bars weld to the axle, they work just like ladder bars. They use axle torque to add traction. As you might imagine, having your rear end welded in place doesn't make for a very comfortable ride. A rear LCA lowering kit and good bushings would be much better for a street car. It will provide improved off the line acceleration and still give you a compliant ride.
Old Jan 21, 2002 | 12:06 AM
cool thanx guys......this is an off topis quesion but what springs should i getfor my 91 that will lower it but stil give a good launch when racing? I hav only heard of Eibach and Hotchki(sp)
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
