Why is one side an inch lower? Eibach sportlines
Old Sep 18, 2021 | 07:36 AM
88BLKTransAmGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 3.77
I added a set of new Eibach sportlines to my 88 gta and the sides are not even height. All numbers are inches from ground to tip fender lip. It has about 100 miles on them since install. Springs all got 1 layer of rubber hose wrapped to the top. Driver front 26" Passenger Front 27"
Driver Back 27" Passenger Back 28"
Is it possibly a shock issue? I tried to install the front strings in the exact spot between the two holes to try to prevent this.
High side
Low side
Old Sep 18, 2021 | 09:42 AM
Abubaca's Avatar
Re: Why is one side an inch lower? Eibach sportlines
I've had a few thirdgens in my days and I've NEVER had both back left and right, and both front left and righ the same height. That being said, 1" is a lot, and having it both on the same side front and back is strange. If you take into account how much these cars flex, it does make sense. Still...your situation is strangely uniform. I don't have a good answer for ya.
Can you measure from the ground, up to the bolt where the front control arm bolts to the frame/K-member? I had my 13 year old help me as I couldn't squish under the car with it loaded on the ground!!!
Old Sep 18, 2021 | 10:58 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I would take a hard look at the passenger rear. If that's high then it will change all the corners but especially cause front diagonal to compress, which kind of seems to be the case.
Old Sep 18, 2021 | 11:19 AM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Wow, and I was upset about the left front being a quarter-inch higher than the right front...
Old Sep 18, 2021 | 12:40 PM
silverstang84's Avatar
Car: 88 IROC
I have sportlines in my car and everything is fine except the drivers side front. It’s about 1” lower then the passenger side front. Drives me nuts
Old Sep 19, 2021 | 06:39 AM
Engine: 5.7 L98
Axle/Gears: 3.77
I'm going to pull the back passenger side and check it out again. Hoping I can get an inch lower out of it somehow.
Old Sep 19, 2021 | 07:58 AM
tomsaddy's Avatar
Car: 1987 GTA
Engine: TT LC9
Axle/Gears: 3.50
I just had a similar issue. One of the springs wasn’t seated in the pocket and it pushed that side up about an inch.
2slow5.0
Sep 9, 2021 08:04 PM
86irocterror
Feb 12, 2008 11:33 PM
gta87ls1
Mar 25, 2007 12:35 PM
mult68
Feb 6, 2006 09:39 PM
GASGZLR
Jun 18, 2004 08:41 AM
