1LE Problems!!!! H E L P!!!!
Old Jan 19, 2002 | 09:41 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I am finally finishing up my 1LE brake upgrade on my Z.I did the rear upgrade this summer when I tore the rear out to rebuild it and waited till this winter to do the front upgrade.My question is when I bought the front pads(Performance Friction #412Z)they came with 4 clips(kinda like a u shape of some sort-I am guessing two per side),are these anti-rattle clips,or better yet...what are they and where do they go??Second,how are the calipers held in their cradles??Pins,bolts,just sit there??Give me a clue guys!!!!Pictures would help a ton if at all possible.I have went to ANDYZ28's 1LE site but can't find a picture that clearly illustrates these two dilema's I am confronted with,and no help from Chilton or Hayne's manuals.Any and all help is greatly appreciated!!TIA
Old Jan 20, 2002 | 12:19 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You need a couple of pins to hold the calipers in. GM P/N 10132826
Old Jan 20, 2002 | 08:59 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
The pin that you see in my attached photo is what retains the caliper in the caliper carrier. It can only be installed in the direction shown (outboard to inboard). It is retaind by an "E" clip.
If you will look carefully just beneath the pin, you will see two small U shaped clips. These are the spring clips you are referrins to. They attach to the rear of the pad metal backing plates. If you look at the pads you will see a small indentation in the tab at one end of the pad. The clip/anti rattle spring attaches there is a small projection on the clip which snaps into the tab on the brake pad.
I hope I have been able to help you.
Thanx,ANDYZ28
Old Jan 20, 2002 | 10:26 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
So I will need 4 of GM P/N 10132826 to hold my calipers in?2 per side I am guessing?Thanks for the help Apeiron and ANDYZ28,the part number and the picture helped out alot,many many thanks!!
Old Jan 20, 2002 | 11:06 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Only 1 pin is required per side. You will also need 1 "E" clip per side.
A long time ago someone said that they got these parts from AutoZone or Advance. It was listed as a brake hardware kit.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
