Need help with rear disc brakes.....
Old Jan 20, 2002 | 03:54 PM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
Okay this might sound REALLY stupid but i am having a headache changing the pads on my '88 gta. I have the caliper off (it was a bitch to get off) and i'm putting the new pads in. THen when i try to slip the cliper over the rotor to bolt it back in it won't go because there isn't enough clearance between the pads for the rotor. I have compressed the piston as much i can with a c-clamp and its still not close at all. So i decide i'll do it another time and i stick the old pads back in there because i have to get to work tomorrow and i run into the same problem. The ebrake still works so i know the caliper isn't frozen. Maybe missing something really simple but i don't know. I've replaced brake pads many times before i never ran into this problem. I have to get to work tomorrow and i can't drive there with a missing brake pad...........
Old Jan 20, 2002 | 04:27 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Make sure the pads are totally flush to where they sit in the caliper,I have been thru that many times.It is usually just one of the pads isn't sitting in the caliper fully causing that headache to happen.
Old Jan 20, 2002 | 08:54 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Something about winding/screwing the calipers parking brake back into the caliper?
Old Jan 20, 2002 | 10:00 PM
wuter's Avatar
yes you have to rotate the piston to undo the adjustment made by the parking brake.
Old Jan 20, 2002 | 10:13 PM
Abubaca's Avatar
You know it's funny, I had the exact same problem today! I also put the old pads back so I could drive to work tomorrow! I could tell that the piston would not budge due to the Ebrake mechanism, but I assumed that it was me who was missing something, and that there was something else wrong. I didn't chech the manual cuz ...I mean...who needs the manual, it's just pads, right? To make a long story short, I did end up checking the manual once the wheels were back on, and sure enough, it seems to screw in. The man. recomends a certain tool. Anyone know a better way?
Learnin' something new every day!
Old Jan 21, 2002 | 12:44 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you don't want to cough up the $5 or so for the tool to screw the piston back in, you can take the e-brake lever off the back of the caliper to let the adjusting screw turn freely, and then use a C clamp or something similar to press the piston back in. (I find part of a steering wheel puller kit works pretty good).
Old Jan 21, 2002 | 11:15 PM
What's this "tool"? any p/n's?
Old Jan 21, 2002 | 11:29 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You can get a universal tool at just about any parts store. It looks like a small cube with bumps sticking out of the corners and holes in the faces for a 3/8" socket drive.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
zayne0
Aug 24, 2015 07:22 PM
