Loud Clunking from 89 Iroc when turning slowly
Car: 1986 Yellow Iroc /1987 Blue Iroc
Engine: All 5.0 LB9 TPI
I’ve noticed a problem with my 89 Iroc-Z
when turning slowly out of my driveway in reverse i heard a very loud banging/clunking which sounded like it was coming from the front end, I checked all my bushings them seem fine, there doesn’t seem to be any play or slop in the wheel, the ball joints are firm and don’t have any give ( they have less than 4k miles on them but they were replaced over 20 years ago) only thing I found a little play in was the tie rods so I replaced them with Moog Tie rods but the problem still persists, the idler arm has a tiny bit of play but nothing that would make a sound like I heard, the car only has 49k miles on it, I also checked my struts which are fine, I’ve noticed it really only happens when turning slowly or turning up onto sharp turns and hills, still a little new to this so any help or advice would greatly be appreciated, I plan on making the car a road trip/ semi daily and want to square away any concerns I have with the car before taking it farther distances just to be preventative
Car: Got me a nice little '86 Z28.
Engine: A brand new 350 with a forged lower
Transmission: 5 speed, TKO600.
Axle/Gears: 10 bolt 373 modified zexel.
Re: Loud Clunking from 89 Iroc when turning slowly
Are you at full lock while turning? If yes there is a rubbing block on the knuckle that rubs on the lower control arm. Can be very noisy.
Car: Looking for a 91-92 camaro.
Engine: Collecting for ls swap turbo
Axle/Gears: 9 bolt 3.27
Did you find and answer?
I’d also check engine and tranny mounts.
Car: 1989 IROC-Z
Engine: L98 350 TPI
Hit all the zerks with a grease gun, see if that does anything.
Fred91GTA
Jul 29, 2002 04:57 PM
