How would you center a 9" in the wheel well??
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Looking for some input on how y'all would so this. So I've got to move the rear end forward about 3/8" to get it centered in the wheel wells. I've got single adjustable control arms on order. Question is how would a guy accomplish this coming from stock length control arms without unbolting both sides possibly creating a mess?? Or unbolt one side and loosen the other to get some wiggle room??
Thanks for the input everybody
Car: '89 Firebird
Engine: 7.0L
Re: How would you center a 9" in the wheel well??
Lay the new arm next to the old and line up the mounting holes and then shorten the new by about 3/8 inch. If you have to make more adjustments then you're going to have to unbolt it.
Double adjustable arms let you keep it on car while making adjustments.
The double adjustable would be nice but it seems like everything is out of stock or two months out. I got these from founders performance a few days away on eBay
Car: '89 Firebird
Engine: 7.0L
In my experience it's easier to install to body side first and then the axle. That's my personal preference anyway with my combination of parts.
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
I little trick I did was use a rachet strap hooked to the axle and the trans mount. Use it to pull the axle forward to line up the bolt holes.
Definitely bolt the body side first and do one at a time. I used non adjustable arms and I still needed to pull the axle forward for the holes to line up.
Oh ya, I think so. Getting the axle droop in the sweet spot is the key. Like anything, first one will be a bugger and take 2 hours and then you'll be a pro and next one will take 1 minute.
Car: '89 Firebird
Engine: 7.0L
The only reason you end up fighting getting things aligned is because of the swing path of the torque arm. If you just attach front torque arm last then nothing will fight you.
I was actually planning on moving my torque arm up at the front to hit the tires a bit harder so I guess that settles it. Setting the pinion angle with this 2 piece race arm is a breeze, 2 jam nuts and give it a twist with my hand.
Screamin82 Z28
May 30, 2020 08:40 AM
86Tra/maro
Apr 17, 2002 12:18 AM
