Watts Link install.
Old Oct 7, 2023 | 03:13 PM
McLovin1181's Avatar
Watts Link install.
My watts Link Video is up. A very interesting suspension part.
kind of annoying to install and expensive.
but overall an improvement over a lowered pan-hard bar setup.
Video:
Pros:
faster lap times
better rear ride quality
​​​​​​​very confidence inspiring on bumpy rough surfaces
cons:
expensive
hard to install
limited on roll center adjustment
Old Nov 1, 2023 | 02:51 PM
alan91z28's Avatar
COTM Editor
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
Re: Watts Link install.
looks great... seems like you like it
what alignment settings are you now running overall with your set up?
Old Nov 1, 2023 | 05:35 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
I didn't think it was terribly difficult to install. The instructions that come with it are pretty clear and emphasize the important areas. I love how it made my car handle. If it weren't so expensive, I'd put one on my other car as well.
Old Nov 2, 2023 | 10:28 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Since you have one too what is you opinion of the ride quality going from a Panhard Rod to a this Watts Link rear suspension?
Old Nov 3, 2023 | 02:28 PM
Mine is installed on my daily driver, and I love it. It's not going to revolutionize your ride, but it will help on uneven roads quite a bit. The best example that I tell people is that when you go through an intersection and the roads aren't even, the stock rear suspension will tend to kind of kick the rear of the car up a little (if that makes sense). With the Fays2, the rear suspension just rolls with the road. The opposite side of the car doesn't react like it does with the panhard rod.
I'd like to get one for my other car as well, but that price point makes it a little difficult at the moment. But maybe one day.
Old Nov 5, 2023 | 01:02 AM
Alignments depend on what you do and what tires you run.
since we have Mc-Struts you need crazy amounts of static camber to cope with the non existent camber curve.
I've run -1.0, -2.0, -3.5 & -4.0 camber on my 3rd gen. really depends on what your build needs.
you'd run about 0.1 degrees of toe IN for a street car.
ZERO toe for track use on courses with long straights.
0.1 deg toe-OUT for a track with a bunch of medium or slow speed corners or autocross
castor past +6.0 is mostly driver feel and preference. (or tire rubbing)
Old Nov 5, 2023 | 02:44 PM
alan91z28's Avatar
COTM Editor
to get that much camber are you also using camber adj bolts on the strut to knuckle interface?
on the caster did you modify the strut tower to avoid the shock hitting the top of it versus factory opening?
it is too bad the factory design is quite challenging with the front suspension and steering
thanks
Old Nov 5, 2023 | 04:32 PM
You should be able to get +6 castor if you use solid strut mounts.
also assuming you aren't running stock strut dust covers or the giant 80s o Bilstein struts.
As far as camber goes, it depends.
My solid mounts are maxed out, but I also don't have a power brake system getting in the way.
I stated the season at -3.0 and ended up with way more than that 6 months later.
Idk how that happened.
& Obviously the lower the ride height, the more camber you get. Even with the Strut suspension
Again, really depends on your car.
My 200tw tires are notorious for needing lots of camber.
Other tires are different
Bald A052
Old Nov 5, 2023 | 07:19 PM
alan91z28's Avatar
COTM Editor
thanks... yes the power brake master cylinder really causes a limit
i am using koni struts without dust covers... i am running about 5 deg caster but noticed it seems pretty close on the caster/camber plate opening... of course the set up of everything will matter, i am using UMI k-member and a arms vs stock
Old Nov 6, 2023 | 02:24 AM
You should be able to get +6.0 caster.
even the stock mounts are capable of +4.5.
I'D guess and say my strut shafts are probably 3/4 of an inch away from the edge of the strut tower opening.
As long as it don't touch.
Also, what is a COTM editor?
Older setup.
Old Nov 6, 2023 | 03:00 AM
vorteciroc's Avatar
Top Answer: 1
Car Of The Month
GeneralDisorder
Members Firebirds
29
Jul 26, 2019 11:12 AM
TheFab
May 26, 2010 05:44 PM
novadk13
Jul 25, 2004 01:46 AM
Ragtop89
South Central Region
Aug 21, 2003 09:45 PM
Afroman
Oct 23, 2002 03:40 PM
