Lowering the stock k member slightly
Car: 1986 Chevrolet Camaro Sport Coupe
Engine: 6.0 LQ9, Truck Norris Cam
Transmission: 4L65E Z Pak clutches, Corvette Serv
Is there a way to slightly lower the k member without having to disassemble the entire front suspension? I'm trying to remove the oil pan from the LQ9 I swapped and I'm missing about 1/2" of clearance
Re: Lowering the stock k member slightly
Rotate the crankshaft. The counterweights are most likely what is preventing the oil pan removal.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Support the engine from above.
Replace the 6 k-member bolts with longer ones so everything stays somewhat in place.
Should do it.
Should do it.
Car: 1984 T/A
Engine: LQ4
last time i had to do that i just removed the two motor mount bolts and raised the engine up a few inches
Do you have the motor mount bolts out and the engine raised? Remove the distributor cap when you raise the motor so it doesn't crack on the firewall. It's easier to raise the bridge than to lower the river.
IROCThe5.7L
Apr 16, 2015 08:17 AM
