oil pan removal with umi k member
Old Feb 22, 2021 | 10:30 AM
88bullet's Avatar
Car: 1988 Camaro IROC Z
Engine: 427 Stroker
Transmission: 700 R4
Axle/Gears: Moser Street axles and 410 Yukon
What's good everybody I had a question don't know if anybody has done it ...if you have a tubular front k member from umi can you drop the oil pan and change the gasket without jacking up the motor and it's a 6-quart pan on a 427 stroker I'm sure that probably makes a difference
Old Feb 22, 2021 | 06:08 PM
alan91z28's Avatar
COTM Editor
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
Re: oil pan removal with umi k member
when i swapped pans with my LS3 still in my IROC i held the engine in place by the crank damper and bell housing blocked up and removed the k-member (i was swapping k members from BMR to UMI anyways)
the problem with the k member in place and getting the oil pan off is how much you need to drop it to clear the pick up from the pan baffle and sides, etc...
some pics in my thread might give you an idea
https://www.thirdgen.org/forums/ltx-...ne-swap-8.html (see post 392)
Old Feb 22, 2021 | 06:17 PM
88bullet's Avatar
Engine: 427 Stroker
Thanks for the tip appreciate the help... Yours looks really nice nothing like a black third gen
Old Feb 23, 2021 | 04:04 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I changed the oil pan gasket on my 427. 6 qrt oil pan also. UMI K member. I had to jack up the motor a bit. Nothing crazy though.
Old Feb 23, 2021 | 04:35 PM
88bullet's Avatar
Engine: 427 Stroker
Awesome thanks
Old Feb 25, 2021 | 10:00 AM
88bullet's Avatar
Engine: 427 Stroker
I forgot to ask you how did you jack up the motor with the cherry picker or did you do it from underneath if you did it from underneath how did you do it
Old Feb 25, 2021 | 03:00 PM
Car: 1988 IROC-Z
Engine: 427 SBC
I used a cherry picker. I didn't have to lift it much. I didn't have to take my distributor cap off as I didn't have to go that high. Although my windshield wiper motor cover hit when I raised it. Had to replace that because it cracked. If you can't get the pan off because your crank is in the way. You might need to rotate the motor some and try again.
Old Feb 26, 2021 | 07:44 AM
88bullet's Avatar
Engine: 427 Stroker
Awesome thanks one more question did you Jack the car up put it on jack stands and then use the engine lift plate on the intake
ItalianIroc-Z
Sep 28, 2017 05:19 PM
baboony
Dec 5, 2010 06:32 PM
Huffs_91_RS
Nov 11, 2005 08:19 PM
Metalifann
Feb 28, 2002 01:25 PM
