Sway bar mount
Old May 27, 2025 | 08:47 PM
Brian Poarch's Avatar
Sway bar mount
Has anyone had issues with the passenger side front sway bar mount bracket not lining up with the holes for the bolts? I Upgraded to the polyurethane mounts for my 36mm front sway bar and the holes do not line up
Old May 28, 2025 | 06:46 AM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Sway bar mount
'Never had a problem with that...
Old May 28, 2025 | 07:49 AM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Re: Sway bar mount
if you're using aftermarket mounts then they will not line up. the factory mounts had offset holes but the aftermarket ones are straight across. UMI makes adapter plates so you can install them
https://www.umiperformance.com/2119-...rackets-front/
here's a picture. you don't have to use the fancy billet mounts. this just shows the straight across mount.
Old May 28, 2025 | 09:29 AM
T.L.'s Avatar
Re: Sway bar mount
Good advice above.
When I installed new poly bushings, I used my factory mounting brackets...
Old May 28, 2025 | 10:46 AM
exiled350's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 427ci Gen 1 Small Block
Axle/Gears: Strange60 4.10 Eaton Truetrac
Re: Sway bar mount
Originally Posted by T.L.
Good advice above.
I just did the same thing, replaced only the bushings and had no issues.
Old May 28, 2025 | 11:22 AM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Re: Sway bar mount
Top Down Solutions sells poly bushings that will work in your stock mounts.
https://www.top-downsolutions.com/36...1983-92-camaro
Worked well for me.
Beater79TA
Aftermarket Product Review
Feb 26, 2019 08:41 AM
Canucksfan1
Jul 5, 2014 01:29 PM
kcb37
Apr 4, 2009 07:45 AM
cali92RS
Dec 9, 2003 10:11 PM
