Installing new sway bars
Old Dec 7, 2003 | 05:45 AM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
Wassup fellas?
Alright, i got my front and rear sway bays, and a wonderbar.
Any tips for installing them? Should i jack up the car or use ramps? What about grease?
Thanks,
Ken
Old Dec 7, 2003 | 06:38 AM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
i'm relatively sure those parts are to be installed with the suspension loaded, so ramps would probably be best, you might wanna grease the bushings if they're polyurethane, mine squeek, no idea about the wonderbar though, sorry.
Old Dec 7, 2003 | 08:29 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
The main swaybar mounts doesnt matter if the car is on tires or not. But the endlinks should be tightened while on its own weight.
I think it would have been easier to mount front bar and wonderbar while having a friend, or jack to help hold things while I started the bolts.
What kind of bushings are you using? Stock rubber, or poly?
Old Dec 7, 2003 | 01:55 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Instaling my version of wonder bar is easier because you can bolt it in place loosely with the extra two outer bolt holes. Then swing up the sway bar and install the sway bar mount brackets to the wonderbar. The installation is covered in the instructions I included with the bar. Ramps would be easier.
Lon
Old Dec 7, 2003 | 03:21 PM
cali92RS's Avatar
Car: White KSwisses
They are poly bushings.
Old Dec 7, 2003 | 05:10 PM
Dale's Avatar
Engine: 350 S-TPI
lonsal, my wonderbar is from you. However, I got the early one that didnt have them extra bolt holes.
Poly bushings should be greased with provided grease. If it didnt come with any I dont know what you SHOULD use. I used regular wheel bearing grease on mine.
Old Dec 7, 2003 | 05:59 PM
lonsal's Avatar
If it is straight poly, then use the special sticky white grease that Energy Suspension sells. I stock it as well. Any synthetic grease will work. But the sticky grease is specially designed to help prevent it from washing out when you go through water.
It was suggested to me by a customer (and I've updated the installation instructions since) to use those outer two bolt holes to hold the bar up while installing it. It makes installation much easier. Otherwise you have to lift the brace and the sway bar up at the same time and thread in a couple of bolts to hold it in place.
I'm considering offering a special "upgrade" discounted price to my customers that purchased my original version of the steering brace. I'll be e-mailing everyone if I decide to do this. I'm in the middle of running another batch currently.
Lon
Old Dec 8, 2003 | 10:09 AM
Engine: V8
relatively sure the special white "sticky" grease is just run of the mill lithium grease...don't shell out for it like it's a rare item, it's not
Old Dec 8, 2003 | 03:36 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
i used ramps... nothing special. i did, however, have trouble lining up one of the brackets that came with the center mounting bushings i had bought, so i just used one of the stock brackets instead. the wonderbar, if i remember correctly, was mounted before the swaybar. try bolting on the endlinks loosely so u can crawl under and bolt up the two center mounts and then tighten up the endlinks. have fun... definitly a worthwhile couple of mods!
Old Dec 8, 2003 | 03:51 PM
lonsal's Avatar
You're wrong, it's not "run of the mill lithium". Lithium based grease is a conventional grease. That grease that Energy Suspension supplies in cute 'lil tubes is a synthetic grease. Super Lube is the equivalent if not the exact same grease. Here is an excerpt from SYNCO's web site: "Super Lube® is a patented synthetic NLGI Grade 2 heavy-duty, multi-purpose lubricant with PTFE. Synthetic base fluids and the addition of PTFE micro powders combine to form a premium lubricant that provides long life protection against friction, wear, rust and corrosion."
Lon
Old Dec 8, 2003 | 06:53 PM
cali92RS's Avatar
Car: White KSwisses
Hey, 90 firebird, u go to csulb?
Im a super-senior, gonna graduate in may.
49er luv!!!
Old Dec 8, 2003 | 06:59 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
you bet i go to csulb! look at my avatar! what color is ur rs? maybe i've seen it around..... i live in the dorms so if ur ever out by the "indian burial ground" parking lot (lot 20?... the one surrounded by dirt right next to bellflower bl/state university dr), u might see my bird... i try to park as close as possible to the front. lol to the "super senior".... hey, u are just experiencing all the university has to offer (i quote van wilder on that one)! take care!
Old Dec 9, 2003 | 10:10 AM
Engine: V8
Lon
good to know, i thank you for setting me straight, sorry for my mistake
Old Dec 9, 2003 | 09:38 PM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
Yeah wonderbar bolts on before the sway bar!
Hey whats that yellow car doing in that picture j/k
Old Dec 9, 2003 | 09:59 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
no idea! for some reason.... i dont think people will be saying that anymore....
Old Dec 9, 2003 | 10:11 PM
Agent13's Avatar
Engine: LG4
What did you do to my car?!?!?! j/k
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
