Sway bar mount bolts
Old Apr 3, 2009 | 11:19 AM
kcb37's Avatar
I have now ordered a wonder bar (steering brace if you don't know) for my car.
However I do not have a sway bar (bought to drag race) so I also do not have the bolts that would normally mount the sway bar to the "frame".
So my question is, does anyone by chance know what size bolts I need.
Stock length will be fine cause I don't have the sway bar mount to go thru.
Old Apr 3, 2009 | 12:01 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Sway bar mount bolts
Check Spohn Performance, they sell bolt kits for sway bars.
Old Apr 3, 2009 | 12:41 PM
kcb37's Avatar
I appreciate the help. I feel kinda stupid now for not even thinking to look at summit or jegs.
You were right spohn does have a bolt kit for the sway bar. $4.95 if someone runs across this.
Also said if I remeber it all correctly grade 10.6 bolts, and zinc something or other plated.
Old Apr 3, 2009 | 06:23 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
if its still matters, they are 10mm1.5 pitch 35mm long
Old Apr 4, 2009 | 12:33 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
If it I sell the sway bar mounting bolts. Upfated tbe link to them on my site.
http://www.top-downsolutions.com/m10-150-x-30-hex-head-metric-flange-bolt
Lon
Old Apr 4, 2009 | 07:45 AM
kcb37's Avatar
Thanks for all the help.
Should be good now.
Sichno
May 21, 2017 07:00 PM
Dubya
Mar 21, 2008 12:36 PM
91banditt2
Aug 22, 2002 08:14 AM
SMURFN' Z28
Jul 8, 2002 08:42 PM
