Wonderbar diementions
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
does any one have the diementions for the Wonderbar?i'm thinking about making my own.
well its long enough to go under the front sway bar bolts!!!
and the flat pieces that go under the sway bar bolts are long enough to make the bar itself right inline to the sway (infront of it)
you can make the bar that goes acroos inline to the sway bar any size you want but you will have to weld that piece to the flat pieces that go under the bolts of the sway bar.
heres is global west's piece..
http://www.globalwest.net/camaro93.h...e%20Connectors
Engine: 5.7 HSR
i know how and where it bolts up i'm just looking for stuff like how long and how thick is the bar that runs across and what is the thickness of the two plates.
Car: 1986 Firebird
Engine: 2.8 V6
Well for how long, youll need to get a ruler. It's that simple.
As to how thick, you can't really go too thick. I wouldn't get stuff with 1/16" wall thickness, maybe 1/8" thickness. Home Depot sells steel in their hardware aisle, in 3 foot, 4foot, 6foot, 8foot lengths. That stuff is "mild steel", if you find a steel store that sells chrome moly (sp?), you could use tubing with a thinner wall thickness.
Car: 4
Engine: 6
Transmission: 5
I wouldn't get too carried away with the weight though; you're bracing 2 pieces of 10 gauge sheet metal (the "frame"), and holding it on with 2 10mm bolts that merely clamp it. Plus of course, it's dead weight right on the nose of the car, out beyond the front tires, where the car already weighs too much. IMHO the stock one is already more than necessary, they just made it out of what they did because it was cheap. IIRC it's about 10 gauge sheet metal brackets with a couple of spot welds holding a piece of 10 gauge rolled non-welded tubing.
I believe if I was going to make one I'd use a flat piece of sheet metal of about the same gauge as the sway bar bushing shells, and break the edges over to make a "U" channel about ¾" x ½" outer. That would cost more to mass produce than stock, but would be just as strong at about half the weight.
Axle/Gears: 3.45, 3.27, 3.27
Then arter MIG welding it in a jig, bead-blast it and send out to powder-coat. You'd wind up with something like this:
Lon Salgren
Top-Down Solutions
Lon Salgren
Top-Down Solutions
Engine: 5.7 HSR
Lon you want to share?what are the diemension of the two mounting pads?
No. Sorry, my tooling and design are all Proprietary. Crawl under your car and measure like I did. Once you've purchsed the steel, designed the bar, cut and machined it, bent it, created the weld jig, MIG welded, bead blasted it and paid for powder coating, you'll discover you didn't even make minimum wage. Of course your labor is free, right? Please understand that this is my livelyhood.
Thanks,
Lon Salgren
Top-Down Solutions
Thanks,
Lon Salgren
Top-Down Solutions
snakeshooter
Sep 10, 2015 07:46 AM
