Wonder Bar
Old Mar 16, 2008 | 12:44 AM
Dubya's Avatar
Car: 89 camaro
Wonder Bar
So, I lost the instructionis where and how to install my wonder bar
can anyone give me the info so i can install it?
Old Mar 16, 2008 | 01:24 AM
83Firebird420's Avatar
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
Re: Wonder Bar
its not hard. where the front sway bar is held on by 3 bolts to the frame, undo them, they are 15mm. the bar will just kinda fall so be careful. put the wonder bar in place, and bring the sway bar back up and hand thread the 6 nuts back in bolt em up, and ur good to go. this is a very nice upgrade, it works!...Makes u wonder why they only did it for the irocs that one year, and not for every 3rdgen.
Old Mar 16, 2008 | 01:41 AM
Dubya's Avatar
Car: 89 camaro
Re: Wonder Bar
awesome. appreciate the help. just want to make sure im gunna be bolting it up correctly
Old Mar 16, 2008 | 02:01 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Wonder Bar
Should look something like this when you finish, this is my UMI wonderbar in front of a 34mm swaybar. Just undo the bushings to lower the swaybar , insert the wonderbar, then reconnect the swaybar bushings. There is only 2 bolts per bushing, so only 4 unless you get the end links too.
Old Mar 16, 2008 | 05:36 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Wonder Bar
If you haven't, you might consider swapping in some poly sway bar bushings and end links while you're at it.
JamesC
Old Mar 16, 2008 | 01:44 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: Wonder Bar
Pic of my Spohn wonder bar with the stock 34mm sway bar:
It's a very simple install. Just loosen the sway bar end links, take off the bolts holding the sway bar to the chassis, line the bolts up with both the wonder bar mounts and the sway bar bushings. This is the fun part...lol. It can be done solo, but a friend would be helpfull. Make sure to tighten the endlinks back up.
Old Mar 17, 2008 | 03:37 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
Re: Wonder Bar
WTF is a wonder bar? was it only for z28 applications? i dont think i have one on my RS am i right someone?
Old Mar 17, 2008 | 03:50 PM
brodysZ28's Avatar
Car: 1983 Camaro Z28
Engine: 383
Transmission: TKO 600
Axle/Gears: Strange S60
Re: Wonder Bar
does it just do the same as a bigger sway bar? limit body roll?
Old Mar 17, 2008 | 04:08 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Re: Wonder Bar
They only came on some IROCs. I doubt you'll have one on the RS, but it's easy to spot if you do.
It's a type of frame stiffener. The two parts of the front sub-frame have no connection at the front. They are just haning out there in space after the motor mounts. This serves as part of the sub-frame and makes the front of the car more rigid. It also reinforces the area around the steering box which is prone to cracking under high stress driving or when running larger wheels (17s and up, or tire widths greater than 245).
Old Mar 17, 2008 | 05:01 PM
JamesC's Avatar
Re: Wonder Bar
The Wonderbar is, quite simply, a Bandaid to strengthen the steering box area (originally on IROC's which at the time were equipped with 16" wheels). It's a nice preventive, and I certainly recommend it as such, but if you're expecting "wonders" from it where performance is concerned, save you money.
JamesC
Old Mar 17, 2008 | 10:35 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: Wonder Bar
JamesC
But it's so cheap, why not put one on?
Old Mar 17, 2008 | 10:57 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Re: Wonder Bar
I actually feel it did wonders for my car. I got the TDS one and the car felt great afterwards
Old Mar 18, 2008 | 01:24 AM
micktroup's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7L V8
Transmission: auto
Re: Wonder Bar
I don't know what JamesC is talking about- I put my Top Down Solutions bar on in about 20 minutes and noticed an improvement DRIVING OUT THE DRIVEWAY! The front end was much more 'connected' to the steering wheel, if that makes sense...the problem with these cars is the multiple ways they flex- anything that stiffens the frame is an improvement.
BTW, the TDS wonderbar is terrific- it has a 3rd hole at each end, which means that once you drop the swaybar, you can use the extra bolt holes to mount the bar with one bolt at each end, THEN swing the swaybar up and remount it. So much easier for those of us that have no friends to help...
Old Mar 18, 2008 | 02:01 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Re: Wonder Bar
Old Mar 18, 2008 | 05:23 AM
JamesC's Avatar
Re: Wonder Bar
Spend the money, feel the difference. I suggest that most people in a blind test couldn't determine whether a Wonderbar was in place or not. At any rate, the brace can't hurt (and if you "feel" a difference, wonderful).
JamesC
Old Mar 18, 2008 | 05:06 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Re: Wonder Bar
I didn't notice any improvement in performance, but the steering did feel better after installing mine. Wasn't a large difference like struts, but there was improvement.
Old Mar 18, 2008 | 05:30 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Re: Wonder Bar
I felt more difference in mine than when I did the struts the month before
Old Mar 18, 2008 | 06:02 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Re: Wonder Bar
Maybe you should have went with better struts...
Old Mar 20, 2008 | 04:12 PM
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
Re: Wonder Bar
I noticed a difference on my 91 RS after I put my TDS wonderbar on... not necessarily in handling (a little bit, but not too much), but the main difference that I notice is when entering driveways at an angle or taking speed bumps and dips anything but straight on. The car makes a ton less noise and the steering wheel doesn't jolt as much as it did before...
It may be all in my head... but I did notice the difference
Old Mar 20, 2008 | 04:30 PM
87 formy's Avatar
Car: 87 formula
Engine: 5.0 TPI
Re: Wonder Bar
I noticed a huge difference after I put in my steering brace, whole car felt a lot more stiff... or maybe it was the subframe connectors I installed at the same time
I have no idea if it made any difference now because I give all of the credit to the SFCs
z28gsxr's Avatar
Car: 91 RS Vert/98 Sierra9
Engine: 5.7/5.0
Transmission: 5spd/auto
Axle/Gears: 4th gen rear with 3.73
Re: Wonder Bar
good to know i just purchased one to put in my 91 vert but haven't gotten around to installing it. once i finish the 5spd swap i'll bolt it on
Old Mar 20, 2008 | 04:46 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Re: Wonder Bar
You could be right, but still I felt a noticable difference with the wonderbar.
Old Mar 20, 2008 | 05:04 PM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Re: Wonder Bar
Has anyone tried the Spohn adjustable wonder bar
Old Mar 20, 2008 | 11:57 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Re: Wonder Bar
So did I. But, the difference from my old 1.5 year old Monroes to the KONIs was huge
Old Mar 21, 2008 | 12:26 AM
Car: 1991 Camaro RS
Engine: L98 350 TPI
Re: Wonder Bar
Here is my TDS Wonderbar on my 91 RS... One of the best improvements I did (next to the L98...) I cant wait to get some SFCs... cuz if the wonderbar does "so little" yet I noticed the difference, I cant wait to see how much the difference SFCs make
Old Mar 21, 2008 | 12:34 AM
Car: 1991 Camaro RS
Engine: L98 350 TPI
Re: Wonder Bar
Oops, forgot to attach the pic
Old Mar 21, 2008 | 12:36 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Re: Wonder Bar
I did too much at once to really tell what did what, but when I added an Edelbrock STB, TDS Wonderbar and bolted-on TDS SFCs, the car felt significantly tighter. However, I'm welding the TDSs on shortly and possibly adding a second set...I still get more creaks and squeaks than I expected...
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
