Anyone using QA1 Proma Star Coil Overs?
Engine: 355 TPI w/AFR 195s Dyno Don Headers
Axle/Gears: Borg Warner 9 Bolt, 3.27 gears
Long story short, I am trying to get a better ride on my 1988 GTA. I have replaced the front (Moog 5660) and rear springs (AcDelco) and replaced the struts/shocks with Koni yellows. I have dialed the as soft as they can be and the car rides rough. I have often heard coil overs don’t help but I talked to QA1 and they claim their new coil overs (Proma Stars) will ride better. Then the next question would be what spring rate? My car is street only so would want a softer spring. I think options are 170, 250 and 350.
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Re: Anyone using QA1 Proma Star Coil Overs?
I checked QA1 charts and they recommend a 250 spring rate for the coil over.
I am going to call them and ask about the car that was at the Hot Rod Power Tour to see if I can talk to the guy that owns that car to see what he is using but also to get his thoughts on the ride and adjustability.
