Front Struts
Old Aug 31, 2025 | 10:32 PM
Eightyninef's Avatar
Front Struts
Just went on Rock Auto. There is still a wide variety of front struts available for our cars. I was surprised. Even AC Delco !!
Old Aug 31, 2025 | 11:47 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Front Struts
Koni?...
Old Sep 1, 2025 | 08:47 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Front Struts
Originally Posted by T.L.
Koni?...
They have rear bilstein and front KYB. The rest is cheap stock replacement
Old Sep 1, 2025 | 09:53 AM
Toon86's Avatar
Car: 1986 Base Firebird
Engine: 2.8L MPI
Transmission: 4 Speed
Axle/Gears: 3.42:1
Re: Front Struts
A lot of the original suspension equipment for these GM cars labeled as ACDelco were actually made by Monroe Auto who were bought up later by Tenneco Automotive. These were extremely well built suspension units and were manufactures in Canada and the U.S.A.
Tenneco in a misguided effort to make more money closed down the Canadian and US facilities and moved production to Mexico and China.
What you are getting now labeled as ACDelco is a poor quality product compared to the original equipment. Poor management and greed has its costs.
Old Sep 1, 2025 | 11:21 AM
ratfink6923's Avatar
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
Re: Front Struts
Just to further your point, in the past month we have received: (2) struts wedged into one AC Delco box (definitely NOT sold as a pair), (3) struts back to back that were stuck in the middle of travel, and fought either way making it impossible to mount to the strut mount (number 4 was manufactured properly" and a shock that had an integrated mount/bushing omitted. All AC Delco "oe replacement " but with the originals discontinued from gm.
Old Sep 1, 2025 | 12:23 PM
Re: Front Struts
So I'll never get an equivalent to a WS6 oem strut : )
Old Sep 1, 2025 | 04:20 PM
Toon86's Avatar
Engine: 2.8L MPI
Axle/Gears: 3.42:1
Re: Front Struts
Never say never.
I helped manufacture these ACDelco shocks and struts for 35 years at Monroe Auto, so I'm a bit of a sucker for the brand, and keeping the car original was a factor. I recently bought ACDelco units, and although the packaging was banged up from transit, they worked OK. Keep your original dirt shields as the new units don't come with them anymore.
If the strut rod doesn't extend when you remove the transit clip it means the nitrogen gas has leaked out and the unit needs to go back for warranty. Once the clips have been removed place the strut rod end on something solid, and push down on the unit. The force required to compress the units should be equal between the pair. Beyond that, fit, ride quality, oil leaks, and squeaks are your only indicator as to their build quality.
Old Sep 2, 2025 | 12:17 AM
Re: Front Struts
I like the OEM look of the ACDelco strut in your picture. However, it's obvious at this point, nothing will equal WS6 specific struts.
I have Bilstein's in my basement, but they are too stiff for daily use. They were great for auto-x and road courses, but I had to take them off for the streets.
I may go with anything on Rock Auto that is black in color.
GAS1951
Aug 28, 2018 10:55 PM
swisscheese
Oct 9, 2011 10:47 PM
NEEDforSPEED
Aftermarket Product Review
Mar 29, 2005 10:55 PM
purpleworm
Mar 7, 2002 02:45 PM
