My drop spindle solution
Old Nov 15, 2025 | 08:16 PM
88Greg's Avatar
Car: 88 Trans am
Axle/Gears: C4 IRS 3.42
My goal with this is :
1.5" drop
Increased neg camber
C7 hub bearing
Bolt on Brake bracket
Bolt-on steering arm to allow for adjustments to Ackerman, steering rate, Bump steer.
Fabricated from laser cut steel plate and welded.
Cad work is done, Some steel parts cut and welded. I should have this thing on the car for fit testing in a day or 2.
Old Nov 16, 2025 | 04:25 PM
88Greg's Avatar
Car: 88 Trans am
Re: My drop spindle solution
Test fit on car. 3D printed steering arm not stiff enough at all for bumpsteer testing, Will have to rig something in metal. Looks like this idea might work, With the camber plate all the way outboard the camber sits at ~ Neg .5 . Going to ponder if thats where I want to leave the design.
Old Nov 17, 2025 | 10:53 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Very cool maybe metal 3d print
83 Crossfire TA
Jan 21, 2023 05:23 PM
Hectori
Apr 22, 2012 04:03 PM
83firechicken
Apr 17, 2011 12:20 PM
Trick414
Jul 6, 2008 02:52 PM
