Monroe Struts
Old Nov 25, 2025 | 11:35 PM
Eightyninef's Avatar
Monroe Struts
Just installed Monroe struts. My WS6 struts bit the dust. The front end is definitely sitting higher. Hopefully it'll settle down in 500 miles...
Old Nov 26, 2025 | 12:06 AM
McLovin1181's Avatar
Re: Monroe Struts
Did you clock the A-arm springs correctly?
Even a few degrees of spring rotation can change your right height by a lot.
Just make sure the spring is barely covering the second hole in the A-arm.
Old Nov 26, 2025 | 07:14 AM
Toon86's Avatar
Car: 1986 Base Firebird
Engine: 2.8L MPI
Transmission: 4 Speed
Axle/Gears: 3.42:1
Re: Monroe Struts
Monroe struts are gas charged so they will sit slightly higher than an old strut that has lost its gas charge. I didn't see a noticeable difference in ride height when I changed mine out. This gas charge should give you a more comfortable ride quality.
I also agree with McLovin, make sure your springs are clocked properly.​​​​​​​
Old Nov 26, 2025 | 07:41 AM
Re: Monroe Struts
Who said anything about changing springs ????????????? !!!!!!!!!!!!!!!!!!!!!!!!!!
you people make up your own magical thoughts just to comment on ??????????????????
Old Nov 26, 2025 | 08:03 AM
GearheadSS's Avatar
Car: Yellow Gold 1986 IROC-Z
Engine: LG4 305
Re: Monroe Struts
This is a great way for folks to ignore your *** next time you ask for help. WTF.
Old Nov 26, 2025 | 09:33 AM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Monroe Struts
Well he does have a point. He asked a question about new struts, Nothing to do with springs. The clocking of the springs doesn't change when struts are replaced...
Old Nov 26, 2025 | 10:01 AM
Beeman's Avatar
Re: Monroe Struts
Struts would have nothing to do with springs and really shouldn't effect ride height. Strut should easily collapse with the weight of the car pushing on them. I could see the car sitting a slight bit higher when lowered from the jacks but once driven ride height should show no difference than worn struts.
Old Nov 26, 2025 | 11:22 AM
Toon86's Avatar
Engine: 2.8L MPI
Axle/Gears: 3.42:1
Re: Monroe Struts
If I recall correctly when I removed the struts on my 3rd gen Firebird, the lower A frame drops down to a point that the spring sits loose enough that it can rotate if bumped. If the spring loses its correct clocking, it can change ride height.
Old Nov 26, 2025 | 06:31 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Monroe Struts
Thats why you support the bottom of the a-arm. Keeps it from droping too much and worse the spring ricocheting out of the pocket and hitting something or someone. If that was done the spring shouldn't of moved.
Most times when i take the weight off the springs or lift the front wheels off the ground. The front end does sit higher, but a short drive settles things back in place.
Old Nov 26, 2025 | 08:01 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Re: Monroe Struts
X2
Old Nov 26, 2025 | 10:40 PM
Re: Monroe Struts
The sway bar end link holds up the control arm when the strut is removed. But that's if you're not smart enough to have a jack under the control arm. and if you're not smart enough to have jack under the control arm, you're probably dead by now from blunt force trauma.
I drove the car 100 miles, everything settled down to normal ride height. BTW, the factory front springs are good for 200,000 miles. They aren't moving. The clock ain't changing. Not even on day light savings time.
Old Nov 27, 2025 | 06:36 AM
Re: Monroe Struts
When doing struts, you don't need to let the control arm "drop" AT ALL. Correct way is, you put the jack under the arm and raise it just enough to get the wheel off the ground, then change out the strut with it like that.
The strut has a very slight effect, heavy emphasis on "slight", due to its gas charge. Might make as much as 1/32" of a difference, if even that. After the car has rolled around for a few feet it'll go back to where it was before, if the springs didn't get disoriented.
blacksunshine'91
Dec 12, 2016 03:40 PM
cmk-2
Jun 20, 2013 07:21 PM
69-er
Nov 22, 2007 10:44 PM
stage20
May 27, 2004 01:20 PM
