how much do rear ends weigh?
Old Jan 29, 2002 | 11:28 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
Old Jan 30, 2002 | 12:16 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
That depends on what parts it has on it. I would say that the drum and disc setups weigh pretty much the same. The big factor is if it is just the housing or the complete rear. I do not claim to be strong or weak, but i have serious trouble lifting a complete rear. Take the drums (or rotors) off and the axles out and i can move it around fine. I assume that you want to ship one? If so, freight is the only way to do it. If you just want to know so you can lug it around.. take as many parts off as you feel necessary.
Old Jan 30, 2002 | 03:35 PM
ATOMonkey's Avatar
If I had to guess I'd say right around or less than 200.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
