Having a hell of a time with the spring compressor
Old Feb 6, 2002 | 06:33 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
My Tokico suspension kit came in and I thought I try to install it tonite. I went to Checker and rented a spring compressor. Is there some trick I am missing using this thing?? First of all to try and keep the hooks on a coil and tighten it is very trying of ones patience. Then when I think I have it on pretty good I find the damn thing sticks out too far on an end so it wont fit in the perch. Any of you guys have some tips or tricks for me before I get anymore pissed?
Old Feb 7, 2002 | 01:32 AM
Tad's Avatar
Tad
I had same problem. The screw is to long for our cars. So I broke down and bought one and cut about three to four inches off the end of the screw.
Old Feb 7, 2002 | 09:32 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
I did the same thing when and bought a crapy on for 15 bucks and cut a little off the top. Make sure you stick it up inside the spring and measure how much to take off the top before you cut it. To keep the arms of the compressor in place I wraped tape around them you may only beable to do this on the bottom I don't remember, but the bottom are the ones that give you the most trouble.
Old Feb 7, 2002 | 11:44 AM
Frank 84 Bird's Avatar
Car: 87 Trans Am
Transmission: TKO 600
When I installed my Eibach's I didn't even use a spring compressor. On the front I pulled down the lower control arm as far as it would go and yanked the old spring out. Since the new springs were shorter they slid right in.
Old Feb 7, 2002 | 12:25 PM
slickrock55's Avatar
Car: 82 Trans am
Engine: Twin turbo 350
I had my springs out a week ago to replace the A-arm bushings, and it was a huge pain in the ***. I dont know if this is stock, but there was a hole ~3/8" in the cup of the spring perch, and it was located perfectly to slide the screw of the compressor into to install the spring. Not sure if this was stock, or a previous owner did it, but in any case, the hole was about a half inch off center towards the outside of the car, in case someone wants to drill their own.
Old Feb 7, 2002 | 12:39 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Thanks for the suggestions. I don't have the engine in the car so I don't have any weight in the front which is probably not helping my sistuation any.
Old Feb 8, 2002 | 04:39 AM
Jza's Avatar
Jza
I had to cut about 2 1/2" off the screw and use a piece of pipe as a spacer to get the spring compressor to work right in order to remove the spring. It wasn't necessary for installation.
customblackbird
Aug 15, 2021 10:16 PM
mhatfield 14
Oct 24, 2015 07:48 AM
TheExaminer
Aug 25, 2015 07:34 PM
rh76camaro
Aug 15, 2015 12:48 PM
novaderrik
Aug 10, 2015 12:44 PM
