Racing Mustang...Broke something..
Old Feb 12, 2002 | 06:48 PM
SilkWorm's Avatar
Someone pulled out in front of me while i was racing a mustang the other day, I had to get into the brakes...REAL..hard. Came to a dead stop from about 60 or so..ended up sitting slightly sideways in a cloud of smoke with the front passenger side leading. Since then i have had a thumping noise (sorry hard to accuretly describe) the noise sounds like it is comming from something that is rotating. I originaly thought that i might have warped a rotor, so i replaced both front rotors, and new pads...the noise is still there. The noise is there at all times acceleration, coasting, decelaration..and can be felt throught the steering wheel. My only thought is that i could have possibly ground one of the tires flat in one spot? Any thoughts any of you have would be greatly appreciated.
82 z28 T-tops
350 four bolt-
Accell blueprint distributor, cap, coil, wires, plugs
Edelbrock intake, Edelbrock preformer carb
Crane cam
headers, 3" exhaust
full front suspension rebuild
700R4 from an 89 iroc proffesionaly built and upgraded
Old Feb 12, 2002 | 07:41 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Sounds like you flat spotted a tire.I have been there before,it is annoying.
Old Feb 12, 2002 | 10:25 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
yup it's a flat spotted tire as mentioned above.
Old Feb 14, 2002 | 11:14 PM
89Irocz23's Avatar
hehe
u know how to fix that right? hehe just put them on th eback and smoke the hell out of them...thats what I had to do.
Old Feb 15, 2002 | 12:15 PM
SilkWorm's Avatar
hehe not a bad idea, think i'll give it a try
Car: 1988 IROC-Z
LOL that would work. just like this----->
Old Feb 16, 2002 | 09:58 PM
LottaBallsCamaro's Avatar
It could also be a bad wheel bearing.(probably not though)
Old Feb 17, 2002 | 03:59 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
Just answer this question and you will have your answer.
Question:
How long does it take to make Cheater Slicks?
Answer:
About 10 seconds
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
