If you have SFCs...
Old Feb 18, 2002 | 01:47 AM
Joel Geerling's Avatar
Car: 91 Formula
Engine: 305 TBI
If you have SFCs...
... Did your passenger-side SFC (Spohn SFC, to be specific) install so close to your y-pipe that the y-pipe bumps it when you put the car in reverse (ie engine rotates just enough)? You can in the picture see how tight the y-pipe / psgr SFC clearance is on mine - is this right? It seems OK I'm worried about the long-term effects of having the exhaust pipe nail the SFC every time I put it in reverse.
Attached Thumbnails If you have SFCs...-psgr-sfc-hits-y
Old Feb 18, 2002 | 02:17 AM
poorboy8's Avatar
Car: 79 Camaro RS
Engine: 355, carb, alum heads, XE262
Transmission: TH350
I rode in a guys car that did that, and he had the Spohn SFC.
Old Feb 18, 2002 | 03:07 AM
SteveSpohn's Avatar
You just gotta re-position your y-pipe (mentioned in the instructions). Loosen the y-pipe connections to the collectors and to the cat.
This is easier with 2 people. With the connections loose, pull the y-pipe away from the SFC using a small pry bar, piece of wood, etc. While holding it in that position re-tighten all the y-pipe connections. The y-pipe will pretty much stay in the same position you were holding it in after everything is tightened up.
Steve
Old Feb 18, 2002 | 03:12 AM
Car: 91 Formula
Engine: 305 TBI
Uh, oh!
And if, say, your y-pipe is welded to your cat? (and cat to i-pipe as well) pls, no comments about how that was a bad idea in the first place.
Old Feb 18, 2002 | 06:41 AM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
... you may want to check to make sure your motor mounts are OK. Mine aren't and I do get a lil noise when I put it in reverse.
Old Feb 18, 2002 | 09:55 AM
Car: 91 Formula
Engine: 305 TBI
Motor mounts are OK. The noise is brand-new as of installing the SFCs anywho...
Old Feb 18, 2002 | 10:33 AM
smurfmobile's Avatar
why not stuff a piece of rubber , like a exhaust hanger between the y-pipe/SFC ?
only problem there could be that the exhaust would/might set it on fire , lol, but rubber isn't all that flammable , hehe
it's a ghetto solution but it would work
Old Feb 18, 2002 | 10:40 AM
Car: 91 Formula
Engine: 305 TBI
LOL that was the only thing that came to my mind when this started happening. I think it would melt and smell aweful, tho. Also, if they were in contact like that all the time, exhuast vibration would be xmitted into the frame/body all the time, right?
Old Feb 18, 2002 | 02:22 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
as mentioned before the correct way to do it would be to loosen the exhaust and reposition it. Or if you want to get lazy about it just stick something between it.
Old Feb 18, 2002 | 06:07 PM
Car: 91 Formula
Engine: 305 TBI
(See my reply above re. welds)
Old Feb 18, 2002 | 06:17 PM
u r sofa king we tah did's Avatar
so the logical solution would be to cut it. it takes about 10 seconds
Old Feb 18, 2002 | 06:21 PM
Car: 91 Formula
Engine: 305 TBI
Ya, cutting it = 10sec, but welding it back together == paying my friend @ exhaust shop b/c I don't have a MIG welder... oh well, I'm picking up the vibe that this is my only option (other than to leave it banging). I should have known better - it all seemed too painless an install.
Old Feb 18, 2002 | 06:26 PM
go rent a exaust pipe flairing tool from autozone for 25 bucks and flare the end to slip. buy the exaust clamps while your at autozone too
Old Feb 19, 2002 | 09:30 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
sorry shows how much I pay attention. You could try header wrap, that should quiet the noise.
Old Feb 19, 2002 | 10:29 AM
Dustin Mustangs's Avatar
Car: I
Engine: Taunt
Transmission: Mustangs
My y-pipe had some clearence issues with my frame directly under the oil pan. When we assembled the y-pipe we didn't notice it untill after we welded every thing up. We heated up the pipe until it was red hot and just bent it in a little with a crow bar. This might impeade flow a little, but not too bad. If you do this just be extra careful what you heat up with the tourch, this can damage a number of differnt parts, duh.
Old Feb 20, 2002 | 06:16 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
If it only bumps when you put it in reverse I would just live with it.
How often do you shift in reverse anyway?
I had my exhuast re-worked at the same time my SFC's were installed and I bought the modified ones from Spohn so it was never an issue. However I don't think a shop would charge to much $$$ to adjust it.
IMO welding is the best way to install and secure exhaust pipes, unless you have a reason to constantly change it (like removing the cat)
Old Feb 21, 2002 | 02:43 AM
toosloz's Avatar
what i did was take a 10 inch piece of old hose and zip tied it to the sfc brace and i have no one bang sound:lala: :hail: :lala: :hail: :lala: :hail:
Old Feb 22, 2002 | 02:01 AM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
My cats are doing the smae thing in two places. I had the spohn dual cat sfc's and theyir great..but when i put the slp 1 3/4's in the cats touch in two places..while idleing in anygear (the rumble of the engine I suppose). Ive been thinking of either doing the rubber idea (car has been slammed 2 inches..so clearance is a huge issue) or trying to re postion the cats without them moving anylower to terra firma.
Old Feb 22, 2002 | 04:36 AM
Car: 91 Formula
Engine: 305 TBI
Have you checked to see how much rubber has melted/burned? Doesn't this create a massive stench? Or does the pipe not get hot enough for it to be a problem??
Old Feb 25, 2002 | 09:34 PM
Cool Runner's Avatar
Car: 86 Trans Am WS6
If you get some poly engine mounts that should eliminate the torque flex that happens when you shift into reverse. This would probrably be the 2nd best solution after adjusting yout y pipe.
oddscrounger
Jun 7, 2013 08:11 AM
Ions91Z28
Sep 4, 2001 06:25 AM
Humvee
Aug 12, 2001 11:34 PM
