BAD VIBRATIONS, I've got Bad Vibrations!!!!
Old Feb 18, 2002 | 01:16 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Guys, you gotta help me out here. I have replaced EVERYTHING THAT SPINS on my car except the engine, and I still have a terrible vibration around 70 mph. So far I have replaced the following items, some may not relate to the vibration, but ho knows:
Switched to IROC Sway Bars, Poly Bushings
Moog Ball Joints, Centerlink, Idler Arm, Pitman Arm
Tightened up my power steering box
Replaced tranny with stock replacement
Replaced Stock Driveshaft with Aluminum driveshaft
Replaced the rear end with a stock unit
I've tried different wheels and 2 sets of tires.
Replaced the rotors
Tubular Panhard bar
There is one thing that I have not checked becuase I dont know how, and I dont know if it matters. I was told that it could be the pinion angle. How can I check this? Is it possible that it could have been tweaked from an accident the car was in before I bought it? And even if it is off a degree or 2, could that cause my vibration? Thanks guys!
Old Feb 18, 2002 | 02:58 PM
irocet305's Avatar
Car: 91 Z28
Engine: L98 350
Transmission: Tire Chirpin A4
I went through 2 sets of tires before I found out I had bad motor mounts. I replaced them with polys, and the bad vibe is gone. Check your mounts just to be sure,
Old Feb 18, 2002 | 10:32 PM
TBI305Camaro's Avatar
if you have an exhaust leak it could cause bad vibs i know mine did
Old Feb 18, 2002 | 10:56 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
also could be your tranny mount
Old Feb 19, 2002 | 02:39 AM
CrazyHawaiian's Avatar
Car: too many ...
can you describe the vibrations a little more? does the whole car shake or do you just hear a noise? my tranny mount was bad and sometimes I would get this awful noise when I floor it. If the whole car shakes ... hmmm .. do your tires wear tread unevenly? was it ever in an accident? (maybe bent frame?).
Old Feb 19, 2002 | 08:21 AM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
Couple things I know about Scott's car..
Its deffinitely not the Tranny mount. He just replaced the Tranny, and I am sure he'd fix it if it were bad. Also, I have had a bad tranny mount, and his vibration is DEFFINITELY not caused by the mount.
His tires aren't in bad condition at all. The tread seems to be wore evently.
I am not sure about the accident thing though.
Old Feb 19, 2002 | 06:21 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
rear drums? replace em.........go here http://www.hunter.com/
do a search for the closest shop that has the gsp 9700 get your tires and rims checked out on it , its a nice machine lemme tell ya
i had bad vibe , replaced driveshaft, got my tires down, turned out to be out of round drums.......also if you have a torque bar you cant have a pinion angle problem...the torque bar runs along side the driveshaft and is connected to the rear axle
69GTOby
Apr 18, 2016 02:34 PM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
sac92transam
Oct 7, 2015 02:31 PM
InfinityShade
Sep 18, 2015 08:32 PM
gta892000
Sep 16, 2015 12:40 AM
