How Low Can You Go!?
Old Oct 14, 2002 | 12:58 AM
  #101
LowCamaro's Avatar
Car: 1985 Camaro
Engine: ......
Transmission: ......
Jacked(almost 7 inches of lift!)
Old Oct 14, 2002 | 01:00 AM
  #102
LowCamaro's Avatar
Car: 1985 Camaro
Engine: ......
Here is my switch panel in place of the old console...
Old Oct 14, 2002 | 01:03 AM
  #103
LowCamaro's Avatar
Car: 1985 Camaro
Engine: ......
And finally my air tank,ill post pics of my driveline compressor tommorow.It fills my tank from 0 PSI to 120PSI in 55 seconds flat at idle!
Old Oct 14, 2002 | 01:15 AM
  #104
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
*** damn that drop looks ****ing bad ***! haha...I was gonna put bags also but then they'd blow up while I was drifting. So I changed my mind and got coil overs.
Old Oct 14, 2002 | 09:31 AM
  #105
FiReBReTHa's Avatar
Bad *** Dood!!
yo, i want you to join team revolution with me.
that way if theres ever a shindig we can cruise together under the same name, plus if you want they can help you get sponsorship down the line! right now working on streetglow.
check it out, www.ar-racing.com
it doesnt take anything to be a member, but i just want it to get big so everyone will recognize the higher up members with bad *** cars, (hence where you come in... ) this is open to any of you, thirdgens need to make an impression on the world.
Old Oct 14, 2002 | 10:09 AM
  #106
FLYNLOW92rs's Avatar
I know what my next project is.........
Old Oct 14, 2002 | 10:11 AM
  #107
LowCamaro's Avatar
Car: 1985 Camaro
Engine: ......
Wellll,thanx guyz.Ive worked hard to get this air suspension right,and ive still got more to go.Im still planning on adding side to side soon and upgrading the valves again to electrics.The valves im usung now are kinda neat,they are a 2 function valve so they can fill and purge(drop) all in itself.They are actually supposed to be used as a brake relay for the big rigs!Now,as for my drive line compressor(the crown jewel!)I got the idea from trukin magazines,air lift company makes and sells one for $900!So i put one together for about $120 canadian.I got a a/c compressor from a blazer,made up some brackets out of 1/4" steel.Got adaptors for the intake and output lines,a small air filter,inline oiler and a water trap.Then i simply wired it to the tank,hooked up a switch and got a longer v belt to stretch over the pulley.Ill post a pic if ive got some time,i gotta go to work.
Old Oct 14, 2002 | 10:30 AM
  #108
LowCamaro's Avatar
Car: 1985 Camaro
Engine: ......
Ok,heres the pic of the compressor,its not the closest up pic but its decent.Ignore the V6 under the hood.Soon an 8 will be dropped in there along with WAY TO MANY other mods this winter!Enjoy..
Old Oct 14, 2002 | 07:44 PM
  #109
You should swap a 91-92 ground effects/nose on that car......it would make it look closer to the ground.......
Also what are the negative things about having air bags and any tips or tricks??? I'll be adding airbags to my ride in about 3-4 weeks and i'm trying to get all the information about them as i can before the install......
Old Oct 14, 2002 | 08:28 PM
  #110
LowCamaro's Avatar
Car: 1985 Camaro
Engine: ......
Actually,its funny that you say that,ive got a 92 nose and gfx in my shop just waiting to be painted and then theyre goin on!Also ive got the 92 style iroc spoiler on order and soon ill have a cowl induction hood!Heres a tip for ya,the front bags must be mounted upside down,so the port is pointing down.This is because there is nowhere for a line to go when its up,i screwed around for 2 hours before i realized this!
Old Oct 16, 2002 | 07:19 PM
  #111
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
Excellent job LowC, looks like you outdid yourself!:hail:
Old Oct 22, 2002 | 01:02 PM
  #112
LowCamaro's Avatar
Car: 1985 Camaro
Engine: ......
Thanx man,so whut have you been up too?
Old Oct 22, 2002 | 05:41 PM
  #113
WE need more pictures.......
Plus i sent you a PM cause i'm really interested in this.......I plan to have my camaro bagged by the end of the year.......gotta work on a budget.......
Old Oct 23, 2002 | 09:33 AM
  #114
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Did you paint your brake drums? :nono:
The drop looks sweet though! Nice job!
Old Oct 23, 2002 | 12:13 PM
  #115
LowCamaro's Avatar
Car: 1985 Camaro
Engine: ......
Yeah those are painted drums behind those 18" rimz.Figure this,the dealership that i bought the car from painted them!I dont know why they did but they did.
Old Oct 24, 2002 | 10:51 AM
  #116
bbunting's Avatar
Car: 1990 IROC Z
Engine: blown 390 CI
Transmission: TKO II
Re: Torq-Thrust IIs
Originally posted by racereno
Well, here's before the lower springs. Maybe I'll have an after photo by next week if I can get time to do shocks/springs/brakes this weekend. Can ya believe I've had this old car over 10 years now. Man, time flies! I wonder how many other RSs came with the leather interior. I've never seen another one myself.
Nice car!
Old Oct 25, 2002 | 06:51 AM
  #117
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
Thanks bbunting (btw did I ever post the after pics?).
LowC, I've had my nose to the grindstone but in my spare time I've been blueprinting a 391ci stroker. Lots of trial fitting and clearance checking.
Again, nice job. I can't wait to see it with the gfx.
Old Oct 26, 2002 | 07:31 PM
  #118
LowCamaro I need your opinion.....
I'm buying a fast bag kit for my camaro that comes with the following items......Do i need anything else besides the custom made bag mounts???
Thanks in advance...
(8) 3/8" SMC Electric Solenoid Valves
(4) Firestone 2500 Series Bags
(1) 5 Gallon 500 PSI Air Tank
(1) Hi-Output Firestone Air Compressor
(1) Steel Braided HIGH TEMP Compressor Air Line 18"
(1) 165 PSI Adjustable Pressure Switch
(65 Ft.) D.O.T. Approved 3/8" SMC Airline
(20 Ft.) 8 Gauge Power Wire
(4) Momentary Rocker Switches for Front, Back, Pancake, and Side-2-Side
All necessary NICKEL PLATED push-in fittings!
Just let me know if i would need anything else......I don't really trust the shops to give me an honest response.....
Old Nov 9, 2002 | 05:03 PM
  #119
LowCamaro's Avatar
Car: 1985 Camaro
Engine: ......
Hm,that coveres alot there.Mount the front bags upside down.The rears right side up,and run the air line strait up to the rear cargo area.Electric compressors suc!You learn that,unless you get a REALLY good one.After a few fills of the tank,youll be hearing that compressor whine(grerererererer)in your dreamz!Whew,thank good for my driveline compressor!
Old Dec 19, 2002 | 02:43 PM
  #120
jfawcett10's Avatar
Car: 1987 Formula Firebird
Engine: 350carb
I must say that i never really cared about air suspension till now.......DAMN!!!
FLYNLOW92rs: did you ever get yours done?
Old Dec 19, 2002 | 02:59 PM
  #121
Right now as it looks, the air bags are gonna be done in Febuary or early March....
I have a couple of projects to do before the air bags go in....
Old Dec 20, 2002 | 02:26 PM
  #122
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
Low...
Old Dec 26, 2002 | 08:14 PM
  #123
FlamedROC's Avatar
Car: 1989 IROC-Z
RU....does that T/A have any problems rubbing on the whell well??
Old Dec 26, 2002 | 09:47 PM
  #124
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Sorry, but I can not answer that. I found the picture online. I would assume the inner fender liners are gone by now..
Old Dec 26, 2002 | 09:54 PM
  #125
FlamedROC's Avatar
Car: 1989 IROC-Z
Ok well I kinda thought that was what u might have done...oh well...my friend did that to his IROC but I dont know if his rubs or not..pretty sure he runs a smaller width tire
Old Dec 31, 2002 | 06:27 AM
  #126
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
I really hope you guys have SFC's
la cooka racha! la cooka racha!
Old Sep 3, 2003 | 11:20 PM
  #127
IROC_5796's Avatar
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
just doing some research on air ride and dug up this old thread. Just wondering if you went ahead with the air ride.....
Old Sep 4, 2003 | 12:11 AM
  #128
I wish i did by now.....I was gonna have them done about 4 months ago, but i spent my money on my current list of mods, it went WAY, WAY overbudget.....
The shaved handles, headlights, lowering, cross-drilled rotors and the custom fenders ate all the money i had set-aside for this......(actually they weren't in the budget).....
Next up is an engine swap, 4th gen rear, and some new rims....Then the air bags, I'm still doing them......but they have been pushed back.....
You may want to look at some of the new posts that LowCamaro has made, he has alot of new pics of his set-up, and shots of it in different positions....As well as Andy Franshaw(spelling may be off), a member from overseas.....He has bought a kit, but i don't know if he has it installed already.....I haven't seen the pics around...
Old Sep 7, 2003 | 02:51 AM
  #129
Andy Fanshawe's Avatar
Car: 91 camaro rs
Yep, that's me!
After finally getting my 91 350 RS to the paint shop (where it is now)-I am currently fitting the air suspension to my '86 sport coupe.
The bags were fitted temporarily to see if they would fit (they did!) and then removed again so all the bracketry can go to be chrome plated. Which they did on friday.
Here is a couple of photos of the front bags and brackets first and the rear bags and brackets next.
As FLYNLOW92rs has found out, other financial plans/projects always seem to get in the way! BUt, I am getting there now. Loads of photos will be taken when things start to go in. Chrome platers have told me about 5 weeks to get all them completed. By then all the suspension will be finished (3/4 of the way there now), so it will just be bolted in. This car is a show car in every sense of the word. A lot of the components around the airbags are chrome plated, so it should look really good.
IROC_5796
Good luck with your research and possible future fitting! I will keep you all informed.
Andy.
Old Sep 7, 2003 | 03:05 PM
  #130
IROC_5796's Avatar
Hey Andy the bags look good. Where did you get them? How much? and what make are they? Did the front bags come with those brackets or did you have to make somthing up? sorry for all the questions Im just really interested in putting them in my car. Oh oh are those fast bags or regular type, im not really sure what the difference is in bag style or if its just the line size. Thanx for any help you can offer.
Old Sep 7, 2003 | 03:17 PM
  #131
Car: 91 camaro rs
Check out
http://www.airliftcompany.com/easyst...indexframe.htm
The brackets are all included. If you buy the above kit, you will need a compressor and various other bits. I was lucky, I bought these secondhand and shipped them over to the UK. Send them an e-mail with your questions, I am sure they will help you.
I am going to try this kit and see what happens.
I will keep you posted on progress.
Andy
Old Sep 7, 2003 | 11:46 PM
  #132
IROC_5796's Avatar
I was reading the points this company gives on there air ride for camaros and firebirds and it says "handles like a race car-flat cornering" http://www.airliftcompany.com/easyst...reetCamaro.htm
Now ive never driven in an air ride car but if anyone who has would like to give there thoughts on this. I was always told it would handle like a cadillac....
Old Sep 7, 2003 | 11:59 PM
  #133
CrazyHawaiian's Avatar
Car: too many ...
I thought Easy Street made kits for our cars. I wonder who will be the first person to body drop a 3rd gen?? LOL!! I love bags, but it didnt match up with the performance I want out of my car so I'm sticking with adjustable spring pertches. I'll get some pics soon ...
Old Sep 8, 2003 | 07:22 PM
  #134
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Originally posted by RU-QWIK
Low...
That's actually a budy of mine's car, he is registered here as Steve86TA. It was a little too low, so he went back to stock WS6 springs with 1 coil cut out IIRC. Looks awesome!
Old Sep 12, 2003 | 06:58 PM
  #135
LowCamaro's Avatar
Car: 1985 Camaro
Engine: ......
Holy shiat, this one was dug up!
Ill re-post tonight...at work gotta go!
Old Sep 15, 2003 | 05:16 PM
  #136
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
I'm wit ya Low...ain't this one kick a** thread!
Old Oct 9, 2003 | 05:38 PM
  #137
Car: 91 camaro rs
Sexy chrome bits for air suspension!
Here y'all go. All brackets ready for the air suspension install are now chrome plated. With a few more assorted things plated at the same time.
Pictures of install coming up.
Andy.
Old Oct 9, 2003 | 11:15 PM
  #138
Re: Sexy chrome bits for air suspension!
Andy.
Can't wait to see the finished product, those brackets look nice, and nice attention to details....
Old Oct 10, 2003 | 03:19 AM
  #139
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
I'll have some new pics with the mods installed in the sig and current set ride height for you guys in day or two also
Old Oct 17, 2003 | 01:07 AM
  #140
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
Ok here's the first couple pics. I can go lower but... then i'll be riding on the fenders in the front.
Here are some shots of the weight jacks installed
and the rear that I put a bunch of anti seize on for some reason
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Giocio
Oct 1, 2015 12:20 PM
