tire rubs, but where?
Old Feb 22, 2002 | 06:11 PM
silentneko's Avatar
hey guys.
ok my left front tire makes a lot of noise, its gotta be rubbing on something but I can't see it, my inner plastic fender is bent from a minor wreck, but only rubs when I turn. when my wheel is straight I can't see anything rubbing, what now
Old Feb 23, 2002 | 12:14 AM
turningfast's Avatar
Take the front tires off and look for a "clean" or worn spot.
Old Feb 24, 2002 | 06:20 PM
360Iroc's Avatar
probably on the fender well
Old Feb 24, 2002 | 06:55 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Mine rub too. When I make hard turns my tires (245/50 R16s) rub on the plastic liners on the front. I'm not to worried about it.
Old Feb 25, 2002 | 10:57 AM
silentneko's Avatar
its rubbing when I'm driving straight, it makes a humm like I'm driving a offroad mudding machine
Old Feb 25, 2002 | 11:14 AM
82camaro's Avatar
Car: 82 camaro SC
I bearing is toast, maybe. Driving down the road, does the sound come and go as you turn left/right? Also check for chopping on the tires--that will make the 'offroad mudder' tire noise.
Old Feb 25, 2002 | 11:27 AM
silentneko's Avatar
its steady and increases with speed, its not a bearing cause it happened as soon as I got the new tire put on. it changes a little as I turn but is still there.
Old Feb 25, 2002 | 01:03 PM
82camaro's Avatar
Car: 82 camaro SC
I bearing sound gets softer and louder as you turn. A bad left bearing will get lounder if you turn right and softer if you turn left. A hum really sounds like a bearing. The front bearings should be repacked every 30000-40000 miles. Replaced if they are noisy. If it's not that, I would take the wheel off and see if it has been touching anything--look for cleaned off spots or worn spots on the wheel/tire. Then spin the brake rotor and see if it's hitting it's shield.
If the tire and wheel aren't hitting anything while you car is at rest I can't see how it could hit anything while you are moving.
edit:
If I could drive it I could tell you with one trip around the block. Find a 'good' shop or mechanic and see if they will give you a free estimate--most will.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
MrPackstin
Oct 25, 2017 08:09 PM
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
Vincent135
Sep 28, 2015 10:50 PM
