Linear Or Progressive???
Old Feb 24, 2002 | 09:45 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i'm looking at all brands of springs here. what is the difference between linear and progressive rate springs. i could care less about the "comfortable" ride. as even in stock form the ride is no where near comfortable. i want all out handling. does anyone know/recomend good high performance springs? as everyone else i would like to lower the car about an inch or so. well thanks for your help guys.
Old Feb 24, 2002 | 04:05 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Linear, hands down.
Old Feb 24, 2002 | 04:33 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
Pardon me while I drool at mystikkal's driveway a moment.... :hail:
My vote is for linear as well. They're supposed to hold the road better.
Old Feb 24, 2002 | 04:37 PM
Car: 1988 IROC-Z
Looks like it the vote is linear. Now for the second question. What brand of linear springs would you guys recommend? thanks again guys.
Old Feb 24, 2002 | 06:03 PM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
Contact the folks at Ground Control for their suggestions.
I'm running a 175 lb/" rear spring with ride height adjusters.
The front will probably be around 500 - 600 lb/", also with ride height adjusters.
Since my daily driver will see double duty road racing starting this season, I wanted to be able to adjust everything in & on the suspension.
Old Feb 24, 2002 | 10:39 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
progressives get stiffer as they compress, linears do not. a leaf spring is progressive, which is why they are good for trucks to carry loads. they are soft under light pressure, but as you add weight, they get stiffer and stiffer.
i won't vote cause i haven't driven a camaro w/ prog rate springs.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Cornholio7979
Sep 20, 2018 02:31 AM
gta power
Convertibles
Sep 23, 2015 09:32 AM
sailtexas186548
Aug 26, 2015 03:32 PM
1985chevydude
Aug 22, 2015 05:36 AM
