What kind of 60' times are you getting with after market suspension???
Old Feb 25, 2002 | 08:09 PM
CamaroX84's Avatar
Mods are in sig. My best 60' time is a 1.892 with a 3.27 posi, stock suspension, and Mickey Thompson ET Street slicks that were not hot enough. Now I have a Spohn adjustable torque arm, Spohn lower control arms and relocation brackets, Spohn sub frame connectors, a 3.42 posi, and a line lock so I can heat up them slicks. What do you guys think I'll be able to pull? It's with a 700R4 trans too. What are you're guys' best 60' times? Please list mods. Thanks.
Old Feb 26, 2002 | 10:23 PM
CamaroX84's Avatar
Anyone??
Old Feb 27, 2002 | 06:24 PM
cy Z28's Avatar
Car: 1989 Formula 350 WS6
Transmission: 700-R4 2600 stall
w/ all that I'd be suprised if you weren't in the 1.5/.16 range.. maybe 1.4 if you're leaving REALLY hard
Old Feb 27, 2002 | 09:14 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Last couple of years I had Spohn torque arm, Herb Adams panhard and LCA arms, home made relocation brackets, air bags inside the springs, rear sway bar, SFCs, factory shocks.
It's all going to depend on how much power the engine can put to the ground. When I was running a SBC and 3.27 gears I was running low 1.7 60 foot times.
Last year with the big block and 4.10 gears my 60 foot times averaged in the high 1.5's
This year I have a transbrake, 4.56 gears and ladderbars so the "aftermarket suspension" stuff is all changed. I'm hoping for 1.4's this year.
You're going to need a lot more engine torque and converter to get below 1.7's
Old Feb 27, 2002 | 11:50 PM
turningfast's Avatar
If he's got a 1.4-1.6 60 fot time, he would have a 9 to 10 second ride. Low 1.8's are probably more realistic.
Old Feb 28, 2002 | 09:04 AM
ATOMonkey's Avatar
I don't want to start a fight, but 60 ft. times are not indicative of 1/4 times. I know guys with 1.6 60 times running in the high 12's because of lack of motor.
Old Mar 1, 2002 | 02:07 AM
cy Z28's Avatar
Lots of LS1 guys are in the 1.6's w/ 325-350rwhp, I don't know why you shouldn't be. If not, it's converter selection and gear selection. A few of them are in the 1.8's w/ nothing but Nitto's.
Old Mar 3, 2002 | 01:31 AM
David 91RS/Z28's Avatar
IMO, I really don't think you'll get much more than low 1.8's out of your combo. Looking at your mph, your probably only pushing about 260-270hp which this also tells about what 60'ft the car is capable of. Suspension isn't necessarily needed all the time. It's mainly tire and track prep. Stock suspension cars can easily pull 1.6-1.7 60ft. I've been a 1.75 with mine and the only thing I have is urethane bushings in the rear LCA and urethane torque arm mount. I do have an aftermarket PHR but this really doesn't do anything for straight line traction. I also run no front swaybar which helps with weight transfer. All my runs are on nitto 275/40's. BTW, I run a 5speed w/ 3.73 gears.
Old Mar 3, 2002 | 12:00 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
So he's going to do a wheel stand, no less?
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Randomtask2
Aug 13, 2015 01:57 AM
novaderrik
Aug 10, 2015 12:44 PM
