spring swap
Old Feb 28, 2002 | 01:13 AM
PimpCamaroRS's Avatar
spring swap
hey i am swapping to intrax springs tomorrow morning and am reading my Haynes guide and see that the back look very easy but the front says that i need a spring compressor or some thin. is this right? or does any one wanna give me some easier instruction or comment or ANYTHING b/c i got to do this tomorrow.
Old Feb 28, 2002 | 02:51 PM
Joel Geerling's Avatar
Car: 91 Formula
Engine: 305 TBI
The fronts are not as easy as the backs (you can do the backs in 10 minutes or less). Just do AutoZone's loan-a-tool (pay for it, use it, then bring it back to get your money back) deal to pick up the spring compressor tools. Be careful!
Old Feb 28, 2002 | 09:47 PM
Chris87TA350's Avatar
Tell me how you like the intrax springs, man. I was thinkin' of getting either those or the Moogs b/c they're so much cheaper than Eibach Pros. Good luck with the install!
Old Feb 28, 2002 | 11:44 PM
dude the were very easy to install sorry for this dumb post....i love them man VERY LOW but excellent look and amazing handling. was totally worth the $189 i paid from summit
Old Mar 1, 2002 | 08:40 PM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
Transmission: LT1 T56
Axle/Gears: 3.73 Moser 12 Bolt
Question guys - since you've all toyed w/replacing springs - my camaro supposedly has Eibach lowering springs in it (well - it DOES have them) but the front ones were in up-side down (installed by 'professionals' supposedly. I've got the springs out and i noticed i don't have the spacer that sits in the sub-frame above the spring. How thick is the spacer supposed to be? B/c I'm deathly afraid that when i correct the springs (right-side-up) they're going 2 lower the car even more (they don't sit right upside down) and the tires were already rubbing. How much should i space those springs in the front? Sorry 4 all the questions.
TP
Old Mar 2, 2002 | 01:14 AM
Car: 91 Formula
Engine: 305 TBI
If the spacer you're talking about is the rubber spring isolator that has a notch for the end of the spring coil sits atop the spring, then just go to the local junkyard and grab some if you can find them. Or buy some at your local GM parts place. They're about 1" maybe 1.5" thick...
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Cameeeero
Sep 18, 2015 04:00 PM
gta90
Sep 15, 2015 04:00 PM
